Hello guys
i m looking for a lisp code over the web for moving block perpendicularly on pline and found following:
(defun c:sto ( / en obj pts_ss ss_len c pten ptobj pted pt pt2)
 (setq en (ssget "_X" (list
            (cons 0 "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,POLYLINE,SPLINE")
            (cons 8 "A-WALL-INTR")
 (princ "\nSelect Blocks: ")
 (setq pts_ss (ssget (list (cons 0 "INSERT"))))
(setq ss_len (sslength pts_ss))
(setq c 0)
 (while (< c ss_len)
   (setq pten (ssname pts_ss c))
   (setq ptobj (vlax-ename->vla-object pten))
   (setq pted (entget pten))
   (setq pt (cdr (assoc 10 pted)))
   (setq cnt 0)
   (while (< cnt (sslength en))
     (setq ename (ssname en cnt))
     (setq pt2 (vlax-curve-getClosestPointTo ename pt))
     (setq cnt (+ cnt 1))
   (vla-move ptobj (vlax-3d-point pt) (vlax-3d-point pt2))
   (setq c (+ c 1))
unfortunately have slight error, please correct it anyone who can,we appreciate in advance gentleman.🙂
here this is error:
STO
Select Blocks:
Select objects: Specify opposite corner: 1 found
Select objects: Specify opposite corner: 0 found, 1 total
Select objects: 1 found, 2 total
Select objects: Specify opposite corner: 0 found, 2 total
Select objects:
error: bad argument type: lselsetp nil
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Command:
Command:
Edited by hosyn
AT THERE AFTER RUNNING COMMAND STILL THERE SOME ERROR INSTEAD CORRECT JOB.🤒
Edited by hosyn
2 hours ago, dlanorh said:
This lisp has been "found" before. See Here
en variable is emtpy , and user still went ahead and select the block, that is why  (sslength en) will produce that error
  • You can remove "X" to enable the user to select on sceen
  • Make sure the selection is under the same layer listed as the filter
(setq en (ssget "X" ;<-- this for selection mode
     (list
            (cons 8 "A-WALL-INTR") ; <--- that layer name
BTW: the lisp code is not that exciting at all 😁
Edited by pBe
  • Thanks 1
:celebrate:this my fult in typing, i wanted to text  EXISTING CODE and auto-correct changed it.
Edited by hosyn
     (list
If I want changed it for closest existing pline someting like that:
     (list
            (cons 0 "POLYLINE")  ;;;; <<<-----the nearest pline to any block
HOW IT BE CHANGED?
Edited by hosyn
     (list
First of all, the "X" at ssget filter will select absolutely all "POLYLINE" on the drawing, and i mean  ALL ,  I take it most it not all blocks are slightly off and you want an easy way to do it. and next you will be needing to align the blocks, etc..
I would suggest to go back to where the original code was "found"  and post you're request there.
EDIT: I see that this requst is related to this, why not continue that thread instead of craeting a new one Hosyn?
Edited by pBe
  • Thanks 1
