ezra Posted June 8, 2020 Posted June 8, 2020 I have made a drawing in Autocad which I imported into Solidworks as a dxf file and am unable to extrude it. I have enlarged the drawing and inspected it to no end, and cannot see any loose ends. Is there a tool in Solidworks 2019 to aid me in finding any errors, or shared joints? I am enclosing the file. Thank you, Ezra Revision A.SLDPRTFetching info... Quote
Cad64 Posted June 21, 2020 Posted June 21, 2020 I don't use Solidworks, but I checked on Youtube and found the video below. Maybe this will help. Quote
vertical horizons Posted July 18, 2022 Posted July 18, 2022 It's not only "loose ends" that can stop an extrusion. If you have an intersection where one line travels a little bit further past the other line, this, too, will stop an extrusion. Quote
