Jest Posted June 8, 2020 Posted June 8, 2020 Sometimes I have problem showing polygon fill in my Autocad Map 3d 2021. After some time of working on my drawing I realize, that polygon fill is not shown anymore. I don't know what action causes this problem. "Apply solid fill" option is enabled, fill exists in object properties.....I checked everything, but I cant see polygon fill. The only solution I know and works, is to close and restart Autocad....but this is annoying. Can somebody tell me, if there is better solution....or what could causes my problem? kind regards Quote
Cad64 Posted June 8, 2020 Posted June 8, 2020 Polygon fill? Are you talking about hatching? Can you post some screenshots so we can see what's happening? Quote
Jest Posted June 8, 2020 Author Posted June 8, 2020 Perhaps I expressed wrongly......I was talking about MPOLYGON fill. Recently I was using closed polylines with hatches. Because sometimes I'd like to hide hatches, I've created different layers for hatches. Unfortunately this method increase number of layers. To avoid this situation I decided to convert Polylines to MPolygons and then turning fill On or Off, by using command FILLMODE, and then choose 0 for Off or 1 for On and regen at the end (I made my own command shortcuts for those two variants to speed up the process). It works just fine, but after awhile...sometimes...I cant switch back to On...even If I draw new Mpolygon, fill is not shown.....nothing helped, except restarting program. Then I could see all Mpolygons propperly, the old ones and newly created. I hope I am more understandable this time.. kind regards! Quote
Cad64 Posted June 8, 2020 Posted June 8, 2020 I just realized you're using Map 3D, not regular Autocad. I have moved your question to the Map 3D section here: https://www.cadtutor.net/forum/forum/47-map-3d/ Quote
