Darren Allen Posted June 7, 2020 Posted June 7, 2020 Good Evening all. Hope everyone is safe and healthy. I am trying to get the rods in the attached file to stretch while getting the ring to copy (array) every 12". Will anyone help me? Thanks in advance. Rebar_Support_3x3x3-8_3D_Dyn.dwg Quote
Cad64 Posted June 7, 2020 Posted June 7, 2020 As far as I know, unless something has changed in the newer versions, you can't Stretch 3D objects in a dynamic block. You can still Array them though, and the cylinders would just stack up end to end. I created a dynamic block of your object, added an Array action, and it seems to work fine. If you want fewer rings, just make your cylinders longer. 1 Quote
BIGAL Posted June 8, 2020 Posted June 8, 2020 (edited) Must it be a dynamic block ? Can be done as a question and draw answer using lisp like cad64 the stirrups and bars are arrayed, just enter the values then draw. Edited June 8, 2020 by BIGAL Quote
