rcb007 Posted June 5, 2020 Share Posted June 5, 2020 I know there are some other ways of doing this, from Lee's Steal routine and then the use of the design center. But I did not know if there was a routine that the user could browse to a file and up pops a dialog box for the user to select which layout tabs to import into the current file? I'm have created matchline areas which has all layout tabs and viewports setup. I already have a plan sheets setup with all the legends and notes needed. I am hoping I could just import those layouts from that file master matchline area. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 5, 2020 Share Posted June 5, 2020 I use design center and Insert>Layout>Layout from Template (easiest to right-click a Layout tab>From Template). No need for a LISP, but I am sure someone can come up with one. 1 Quote Link to comment Share on other sites More sharing options...
rcb007 Posted June 5, 2020 Author Share Posted June 5, 2020 Thank you for the input! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 6, 2020 Share Posted June 6, 2020 Hi, You can try my Import Layout program for a few times before it expires. https://autolispprograms.wordpress.com/import-layouts/ Quote Link to comment Share on other sites More sharing options...
