I know there are some other ways of doing this, from Lee's Steal routine and then the use of the design center. But I did not know if there was a routine that the user could browse to a file and up pops a dialog box for the user to select which layout tabs to import into the current file?
I'm have created matchline areas which has all layout tabs and viewports setup. I already have a plan sheets setup with all the legends and notes needed. I am hoping I could just import those layouts from that file master matchline area.
I use design center and Insert>Layout>Layout from Template (easiest to right-click a Layout tab>From Template). No need for a LISP, but I am sure someone can come up with one.
Thank you for the input!
