Offset to a specific layer
Dahzee
21 hours ago, Tharwat said:
No worries, try it and let me know. :)
(defun c:Test (/ n c f i s e o)
  ;;	Author : Tharwat Al Choufi			;;
  ;; website: https://autolispprograms.wordpress.com	;;
  (setq n "Layer" ;; Target layer name.	;;
        c 232     ;; Colour of Layer.	;;
        f 0.8     ;; Offset distance.	;;
  (and
    (or (tblsearch "LAYER" n)
        (entmake (list '(0 . "LAYER")
                       '(100 . "AcDbSymbolTableRecord")
                       '(100 . "AcDbLayerTableRecord")
                       (cons 2 n)
                       (cons 62 c)
                       '(70 . 0)
    (setq i -1
          s (ssget "_X"
              (list (cons 410 (getvar 'CTAB))
                    '(0 . "LWPOLYLINE")
                    '(-4 . "&=")
                    '(70 . 1)
    (while (setq i (1+ i)
                 e (ssname s i)
      (and (setq g (entget e)
                 o (entlast)
           (vlax-write-enabled-p (vlax-ename->vla-object e))
           (vl-cmdf "_.OFFSET"
                    f
                    e
                    "_none"
                    (mapcar (function (lambda (j k) (* (+ j k) 0.5)))
                            (vlax-curve-getstartpoint e)
                            (vlax-curve-getpointatparam e 2)
           (not (= o (setq o (entlast))))
           (entmod (subst (cons 8 n) (assoc 8 (setq e (entget o))) e))
) (vl-load-com)
Thanks, it worked fine :)
Excellent, you are welcome anytime. :)
