rcb007 Posted June 2, 2020 Posted June 2, 2020 I cannot seem to get this command to run through a DCL. When I load it normally. It works as expected. Is there something I could be missing in the way that it is setup? (It is to ungroup selected objects in the drawing.) Again, it not work when I select through the dcl button. Thanks for any help! (defun c:UGMO ( / idx grp selt ) (if (setq selt (ssget)) (repeat (setq idx (sslength selt)) (if (= "GROUP" (cdr (assoc 0 (entget (setq grp (cdr (assoc 330 (entget (ssname selt (setq idx (1- idx))))))))))) (entdel grp) ) ) ) (princ) ) 1 Quote
dlanorh Posted June 2, 2020 Posted June 2, 2020 A DCL dialog is modal. That means nothing can run whilst the dialog is displayed. To run something you must hide the dialog, then reinstate it. See Here 1 Quote
rcb007 Posted June 4, 2020 Author Posted June 4, 2020 Got it! Thank you. Sorry for the late response. Quote
