toxicsquall Posted May 25, 2020 Posted May 25, 2020 Please, I need help to make a LISP to execute this comands in this order. Can you help me? ZOOM (EXTEND) > SELECT ALL OBJECTS > FLATTEN (REMOVE HIDDEN LINES = NO) > COLOR CONTROL = ALL BY LAYER > LINE TYPE CONTROL = ALL BY LAYER > LINE WEIGHT CONTROL = ALL BY LAYER > PURGE (PURGE ALL ITEMS) Can you help me? Quote
dlanorh Posted May 25, 2020 Posted May 25, 2020 59 minutes ago, toxicsquall said: Please, I need help to make a LISP to execute this comands in this order. Can you help me? ZOOM (EXTEND) > SELECT ALL OBJECTS > FLATTEN (REMOVE HIDDEN LINES = NO) > COLOR CONTROL = ALL BY LAYER > LINE TYPE CONTROL = ALL BY LAYER > LINE WEIGHT CONTROL = ALL BY LAYER > PURGE (PURGE ALL ITEMS) Can you help me? Does the flatten, color, linetype and lineweight all bylayer apply to objects within blocks? Quote
dlanorh Posted May 25, 2020 Posted May 25, 2020 OK, try the attached. If you want entities within blocks included, it will need a few extra lines of code. AllByLayer.lsp 1 Quote
BIGAL Posted May 26, 2020 Posted May 26, 2020 Maybe something like this ; converts blocks to bylayer proerties (setq doc (vla-get-activedocument (vlax-get-acad-object))) ; open database (vlax-for block (vla-get-blocks doc) (if (not (wcmatch (strcase (vla-get-name block) t) "*_space*")) (vlax-for ent block (vla-put-color ent 0) (vla-put-linetype ent "Bylayer") (vla-put-lineweight ent aclnwtbylayer) ) ) ) 1 Quote
