jntm226 Posted May 24, 2020 Posted May 24, 2020 (edited) hello everyone. Probably I found a bug with the VBScript. I was creating and experimenting a lot with the VBScript function if-then-elseif-else statement and I found something that before saving my drawing was working, but know that I was checking again simply stop working. I was linking multiple functions to the function name "NAME_BY_OBJECT" which generates a different name per each different object. In images 1 and 2, everything is correct... ... but something weird happens with I add the object type "Hanger": ... again everything works correct, but just with hangers, but I was checking the cable trays and cable trays fitting this happens: I do not what happens here. Then: 1) am I doing something bad? 2)if yes, how can I fix this? 3) if not, What Is wrong, and what alternatives exist? PD: attached files before: If "[ObjectType]" = "Cable Tray" Then RESULT = "[NAME_CABLE_TRAY]" ElseIf "[ObjectType]" = "Cable Tray Fitting" Then RESULT = "[NAME_CABLE_TRAY_FITTING]" Else RESULT = "NA" End If after: If "[ObjectType]" = "Cable Tray" Then RESULT = "[NAME_CABLE_TRAY]" ElseIf "[ObjectType]" = "Cable Tray Fitting" Then RESULT = "[NAME_CABLE_TRAY_FITTING]" ElseIf "[ObjectType]" = "Hanger" Then RESULT = "[NAME_HANGER]" Else RESULT = "NA" End If property bug with hanger added.dwg property bug.dwg Edited May 24, 2020 by jntm226 Quote
