Hi,
I have Autocad Mechanical and DX.
Now retired and wondering what I can do with the software and licences, is there any value?
Regards
You can't legally resell Autodesk software, so no, there is no value.
If you had a company you can sell your company and its assets including Autocad. Need to check the EULA carefully.
That would also depend on the age of the software, anything from 2010 or earlier will no longer be activated by Autodesk and from march 2021 the same restrictions will start to be applied to 2016 and older software. Any software already activated is fine so long as you don't need to re-activate, so updating to a new computer or even just a Windows update can cause the need to re-activate, effectivley ending your use of older versions.
Thank you all for the replies.
Pity to just burn it all.
