how can I change “GETPOINT” z-axis value? I need always z-axis value “0”.
Because when I am taking with getpoint, one line distance if the line has z axis that also it will come to that length. Am drafting 2d I don’t want 3d. so when I will get the quantity it's coming wrong
(defun c:test()
  (vl-load-com)
(setq acadobj (vlax-get-acad-object)
      doc     (vla-get-activedocument acadobj))
(setq pt1     (vla-getpoint (vla-get-utility doc) nil "\nPick 1st point for length")
      pt1v (vlax-variant-value pt1)
      pt1zv  (vlax-safearray-get-element pt1v 2))
 (vlax-safearray-put-element pt1v 2 100.00)
 (setq new-zvalue (vlax-safearray-get-element pt1v 2))
(setq pt2     (vla-getpoint (vla-get-utility doc) nil "\nPick 1st point for length")
      pt2v (vlax-variant-value pt2)
      pt2zv  (vlax-safearray-get-element pt2v 2))
 (vlax-safearray-put-element pt2v 2 100.00)
 (setq new-zvalue (vlax-safearray-get-element pt2v 2))
(entmake (list (cons 0 "line")(cons 8 "01-identity")(cons 10 pt1)(cons 11 pt2))))
(setvar 'osnapz 1) ; 2D
(setvar 'elevation 100.) ;plan elevation
(defun c:test ( / pt1 pt2)
  (ai_sysvar '(("OSNAPZ" . 1)("ELEVATION" . 100.0 )))
  (and (setq pt1 (getpoint "\nPick 1st point for length "))
       (setq pt2 (getpoint pt1 "\nPick 2nd point for length "))
       (entmakex    (vl-list* '(0 . "line")
              '(8 . "01-identity")
              (mapcar ''((a b) (cons a (trans b 1 0))) '(10 11) (list pt1 pt2))
  (ai_sysvar nil) ; restore sysvar
hanphuc provided a good solution sometimes the point is xyz but Autocad input is XY so a simple work around is
(setq pt1 (list (car pt1)(cadr pt1)))
Expand
(setvar 'elevation 0.000) or edit previous code
  (ai_sysvar '(("OSNAPZ" . 1)("ELEVATION" . 0.000 )))
  ;;<snippet>
BIGAL 's 1+3 others to suppress z , i.e. x,y only
1.scale 1 unit
(mapcar '* '(1. 1.) pt1)
2.butlast
(cdr (reverse (cdr pt1))
3.LM's addition
(mapcar '+ '(0 0) pt1)
