Hi,
I would appreciate if someone could help me with a lisp to explode all dimensions in multiple drawings in AutoCAD.
I know exploding dimensions is not the best, however I have to do it for this specific project and I have a lot of drawings.
Give this a try .. welcome to CadTutor :)
(defun c:foo (/ a d el s)
  ;; RJP » 2020-05-18
  (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  (if (setq s (ssget "_X" '((0 . "DIMENSION"))))
    (foreach e (mapcar 'cadr (ssnamex s))
      (vlax-for	a (vla-item (vla-get-blocks d) (cdr (assoc 2 (setq el (entget e)))))
	(entmakex (append (entget (vlax-vla-object->ename a))
			  (list '(8 . "Busted_Dims") '(62 . 8) (assoc 410 el))
      ;; Entdel does not work on layouts
      (vl-catch-all-apply 'vla-delete (list (vlax-ename->vla-object e)))
  (foreach l a (vlax-put l 'lock -1))
(vl-load-com)
Edited by ronjonp
  • Like 4
10 hours ago, BIGAL said:
Posted at forums/Autodesk. It would be useful if people stated posting else where.
OP mentioned multiple drawings in AutoCAD
i tested your script it's not working.
not sure putting ronjonp's routine in script. eg: "exdim.scr"?
p/s: i just realized vla-explode method does not support dimensions!! hat's off ronjonp's 👍
Edited by hanhphuc
Thanks! 🍻
hanhphuc I did not test script like every one here time has a cost so just tested on a single open dwg just suggested something like that sequence could work. Using the lisp to do the work is more reliable.
no worries Al, just play around a bit neither my attempt working.
AFAIK script looks like entering command line, every space counts.
it seems easy writing script but clueless
my attempt was putting a standard command like your example as well as Ronjonp's code in xpdim.lsp
(defun xpdim ( / ss )
  (setvar 'qaflags 1)
  (if
    (setq ss (ssget "_X" '((0 . "DIMENSION"))))
    (vl-cmdf "_explode" ss "")
  (setvar 'qaflags 0)
then i wrote this script, test.scr
all put in path folder D:/TEMP/
open "D:/TEMP/TEST1.dwg" (load "D:/TEMP/xpdim.lsp") (c:foo) qsave close
open "D:/TEMP/TEST2.dwg" (load "D:/TEMP/xpdim.lsp") (xpdim) qsave close
open "D:/TEMP/TEST3.dwg" (load "D:/TEMP/xpdim.lsp") (c:foo) qsave close
command: SCR
Only the 1st TEST1.dwg (c:foo) worked , but it failed in the next drawing
error shows:
  Unable to find requested file: "qsave.dwg"
p/s: using BCAD
Put the qsave close in the lisp. Can not remember if need space after (load …)
I use dir *.dwg /b >dirlist
The use word using replace ^p to add all the correct commands before or after the end of line. Copy and paste to notepad the final as word has a nastyadding hidden characters even if saving as text.
Replace ^p open ^p
Replace ^p  (load "D:/TEMP/xpdim.lsp")^p
