Hello,
I have a titleblock with attributes,  where I would like to change attributes using lisp. I tried Lee-Mac routiens, tried JTB with no luck,
i guess it have something to do with the fact my block is dynamic, or something
(entget (car (entsel)))
Select object: ((-1 . <Entity name: 1746772d820>) (0 . "INSERT") (5 . "DA2") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 1746772d830>) (102 . "}") (330 . <Entity name: 1746772eed0>) (100 . "AcDbEntity") (67 . 1) (410 . "01 А2") (8 . "0") (100 . "AcDbBlockReference") (66 . 1) (2 . "*U8") (10 589.0 5.0 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0))
i am trying to change the PAGES attribute... btw
so there is some trick, and i just cant figure it out. I'd be happe to provide the block, but I am unable to make attachment to post.
Thanks for help
Sample.dwgFetching info...
Yes the problem is caused by the fact that your block is dynamic, but there are a couple of simple workarounds for this. I cannot open your drawing as it is in a later version of AutoCAD than mine (2012). If you re-post the drawing saved as 2010 or earlier I'll have a look.
Is this a one off change, or are you trying to automate updating several instances of the block to be numbered sequentially over several layouts?
Thanks,
here is a AC2010 file + the script i am using.
its only one block per file i need to change and its in a layout.
PS: i cannot use the COM style commands, i am using script in accoreconsole batch commands.
Thanks for help
Sample2010.dwgFetching info... test_attr.scrFetching info...
Edited by janickovic
OK. Attached is updated lisp and the drawing I tested it on. I copied the single layout to make three layout to test across multiple layouts. Tested and working.
I have enclosed the last part of your "script" into a (c:) defun named test. Once loaded type test. You can rename this to whatever you want. The script finds all blocks in paperspace and filters by the effectivename property to match  "_TITLEBLOCK_MAIN". This is in uppercase to avoid case problems matching strings using the "=" function. The lisp can be run from paperspace or modelspace as I have altered the ssget filter to attributed blocks NOT in modelspace .
test_attr1.lspFetching info...
Edited by dlanorh
thanks very much , but as i mentioned i cannot use vlax- methods, they do not work in AutoCad CoreConsole, it have to be pure lisp.
I noticed that on my edit. See attached version. You'll need to rename the ext from ".lsp" to ".scr". NOT tested
test_attr2.lspFetching info...
yes, i was just about to post it worked after two "typos"
  On 5/10/2020 at 6:16 PM, janickovic said:
Thanks very much!
Not a problem. My excuse is that I always use "ss". The (strcase) error was just a brainfart. :lol:
