RepCad Posted May 9, 2020 Posted May 9, 2020 Hi every one, I'm using this code to get unique serial of any system : (setq nu (vlax-get-property (vlax-invoke (vlax-create-object "Scripting.FileSystemObject") 'Getdrive "c:" ) "SerialNumber" ) ) It works well for each system, but only problem that I have with the code is that the serial number changes when widows changes. or it gives two different serial numbers when computer has two windows (two operations). is there a permanent serial (unchangeable) on system and unique for each system? Quote
Lee Mac Posted May 9, 2020 Posted May 9, 2020 Use the MAC address instead of a HDD serial number, the NIC is far less likely to be replaced. 1 Quote
RepCad Posted May 12, 2020 Author Posted May 12, 2020 The Mac address also changes with the change of windows. Quote
Lee Mac Posted May 12, 2020 Posted May 12, 2020 4 hours ago, amir0914 said: The Mac address also changes with the change of windows. No it doesn't - the MAC address is a physical address hard coded into the hardware and is therefore independent of the OS. 1 Quote
