Erase Object in Specific Area at Several Layout
irahalulus
Sorry, I'm newbie.
I just want to erase some object (viewport) in Specific Area at Several Layout. Every layout actually have the same position of object.
When this script work, I will make the (repeat n) version....
(defun c:xxxx ()
  (setq p1 (getpoint "\np1: "))
  (setq p2 (getpoint "\np2: "))
  (setq seleksi (ssget "C" p1 p2))
  (setvar 'ctab (car (layoutlist))) ; move to first layout
  (command "erase" seleksi "")
  (command "rectangle" p1 p2 "")
  (setvar 'ctab (cadr (member (getvar 'ctab)(layoutlist)))) ; next layout
The problem is: for example, the active layout is the 3rd layout, and then I run this script.
It will only erase the object in the 3rd layout. But, it success to make rectangle in every layout...
I have no idea why this can happen. Thx in advance.
If you are in the third layout then the selection set contains entities only in that layout. Similar entities in the same location in other layouts will not be selected. You must  make a selection set in each layout.
  (foreach lout (layoutlist)
	(setq seleksi nil)
  • Thanks 1
Thx in advance. I have gotten the idea.
Here's another way without iterating the tabs .. assumes that the viewport is in the EXACT same spot.
(defun c:foo (/ e p s)
  ;; RJP » 2020-05-08
  (if (and (setq e (car (entsel "\nPick viewport to delete: ")))
	   (setq p (vl-remove-if-not '(lambda (x) (member (car x) '(0 10 40 41))) (entget e)))
	   (setq s (ssget "_X" p))
    (foreach vp	(mapcar 'cadr (ssnamex s))
      (vl-catch-all-apply 'vla-delete (list (vlax-ename->vla-object vp)))
