This attribute is Area field of closed polyline, then follow with the text suffix.
Eg. 15.3m2 (AT). I want to get the areas sum of all selected into a table (as field).
It would probably be simplest to go back a step and use the direct fields of the pline areas and not the attribute in your table.
Thanks Bigal but there are too many to go back. There are many in a dwg and many dwgs and also it's our standards.
Example as Dwg attached (simplified and much smaller size) are 10 areas I wish to sum up and output onto a table in the dwg.
Ignore the table on top right corner, it's just a table example that was manually created.
AreaG.dwg
Srory can not help "also it's our standards." that includes student version ?
