Ajmal Posted May 5, 2020 Posted May 5, 2020 What is the problem? FILLETRAD not setting (defun c:test() (setq der(getstring(strcat "\test <" (vl-princ-to-string der)"> : "))) (setvar "FILLETRAD" der )) i give "500" then it will come AutoCAD variable setting rejected: "FILLETRAD" "500" Quote
hanhphuc Posted May 5, 2020 Posted May 5, 2020 On 5/5/2020 at 11:50 AM, Ajmal said: What is the problem? FILLETRAD not setting AutoCAD variable setting rejected: "FILLETRAD" "500" Expand should be real number not string (defun c:test (/ r) (initget 7) (setq r (getreal (strcat "\nTest <" (rtos (getvar 'filletrad) 2) "> ? : ") ) ) (setvar 'filletrad r) (princ) ) Quote
BIGAL Posted May 6, 2020 Posted May 6, 2020 Another just down load multi getvals.lsp from download area. (defun c:test ( ) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setvar 'filletrad (atof (nth 0 (AH:getvalsm (list "Enter radius " "Current radius " 12 11 (rtos (getvar 'filletrad))))))) ) Quote
hanhphuc Posted May 7, 2020 Posted May 7, 2020 On 5/6/2020 at 12:02 AM, BIGAL said: Another just down load multi getvals.lsp from download area. (defun c:test ( ) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setvar 'filletrad (atof (nth 0 (AH:getvalsm (list "Enter radius " "Current radius " 12 11 (rtos (getvar 'filletrad))))))) ) Expand nice, i remember something similar, LISPED how it looks like? (LISPED "Your string here") in Briscad it does not exist Quote
BIGAL Posted May 9, 2020 Posted May 9, 2020 All the multi xxx .lsp work in Briscad there are 4 in "Downloads" Grrr has some nice ones also as library dcl's. Have as many entries as required limited by screen size. Quote
