Ahmed_Hisham Posted May 4, 2020 Posted May 4, 2020 Good Day, I want the attached code to run as QDIM in Autocad , My issue in my code that I choose the location of the dimension line after that the dimension appears. I want to see all the dimensions afterwards choose the location like in QDIM command. Thanks (vl-load-com) (defun C:FH ( / *error* doc oVAR ss i pts ptsx ptsy d d0 filter ) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg))) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ)) ;------------------------------------------------------------------------------------------------------ (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (foreach e '(CMDECHO ORTHOMODE) (setq oVAR (cons (cons e (getvar e)) oVAR))) (setvar 'CMDECHO 0) (setvar 'ORTHOMODE 0) (if (and (princ "\nNeed blocks, ") (setq ss (ssget (list '(0 . "INSERT")))) (< 1 (setq i (sslength ss))) (while (not (minusp (setq i (1- i)))) (setq pts (cons (cdr (assoc 10 (entget (ssname ss i)))) pts))) (setq ptsx (vl-sort pts '(lambda (p q) (< (car p) (car q))))) (setq ptsy (vl-sort pts '(lambda (p q) (< (cadr p) (cadr q))))) (setq d (abs (/ (- (car (last ptsx)) (caar ptsx)) ;xmax-xmin (if (zerop (setq d0 (- (cadr (last ptsy)) (cadar ptsy)))) ;ymax-ymin 0.001 d0)))) (setq pt (getpoint "\nSpecify dimension line location: ")) (or *DimTypeBDA (setq *DimTypeBDA "Aligned")) (not (initget "Horizontal Vertical Aligned")) (setq *DimTypeBDA (cond ((getkword (strcat "\nType of dimension [" (cond ((> d 1000.) (if (= *DimTypeBDA "Vertical") (setq *DimTypeBDA "Horizontal")) "Horizontal") ((< d 0.001) (if (= *DimTypeBDA "Horizontal") (setq *DimTypeBDA "Vertical")) "Vertical") ("Horizontal/Vertical")) "/Aligned] <" *DimTypeBDA ">: "))) (*DimTypeBDA))) (setq pts (if (or (= *DimTypeBDA "Horizontal") (and (= *DimTypeBDA "Aligned") (> (- (car (last ptsx)) (caar ptsx)) (- (cadr (last ptsy)) (cadar ptsy))))) ptsx ptsy)) (setq i 0) ) (repeat (1- (length pts)) (cond ((= *DimTypeBDA "Horizontal") (command "_.DIMLINEAR" "_none" (nth i pts) "_none" (nth (1+ i) pts) "_H" "_none" pt)) ((= *DimTypeBDA "Vertical") (command "_.DIMLINEAR" "_none" (nth i pts) "_none" (nth (1+ i) pts) "_V" "_none" pt)) (T ;Aligned (command "_.DIMALIGNED" "_none" (nth i pts) "_none" (nth (1+ i) pts) "_none" pt))) (setq i (1+ i))) (princ (strcat "\nError: Wrong selection of at least 2 BLOCKS."))) (foreach e oVAR (setvar (car e) (cdr e))) (vla-endundomark doc) (princ) ) FH Final.LSPFetching info... Quote
Stefan BMR Posted May 4, 2020 Posted May 4, 2020 See the answer here and let me know if it's what you want. 1 Quote
hanhphuc Posted May 5, 2020 Posted May 5, 2020 (edited) This is a simple transient effect in visualizing Qdim lines. you can try LM:grtext as well (defun gr-lines (i co pt l / k ip-lst lastp) ;hp 04.05.2020 (defun ip-lst (pt c v1 v2 l) (grvecs (apply 'append (setq l (mapcar '(lambda (p / ip) (if (setq ip (inters pt (mapcar '+ pt v1) p (mapcar '+ p v2) nil ) ) (list c ip p) ) ) l ) ) ) ) (mapcar 'cadr l) ) (while (and pt (setq k (grread t 13 0)) (= (car k) 5) (setq pt (cadr k)) (vl-consp pt) ) (redraw) (cond ((= i 0) (setq l (vl-sort l '(lambda (a b) (< (car a) (car b))))) (grvecs (list co (list (caar l) (cadr pt)) (list (car (last l)) (cadr pt)) ) ) (ip-lst pt co '(1 0 0) '(0 1 0) l) ) ((= i 1) (setq l (vl-sort l '(lambda (a b) (< (cadr a) (cadr b))))) (grvecs (list co (list (car pt) (cadar l)) (list (car pt) (cadr (last l))) ) ) (ip-lst pt co '(0 1 0) '(1 0 0) l) ) ((= i 2) (mapcar '(lambda (a b / ip) (if (setq ip (apply 'ip-lst (vl-list* pt co (reverse (cons (list a b) (mapcar '(lambda (x) (polar '(0 0 0) (+ x (angle a b)) 1)) (list (/ pi 2) 0) ) ) ) ) ) ) (apply 'grdraw (append ip (list co))) ) ) l (cdr l) ) ) ) (setq lastp pt) ) lastp ) Try to modify add function call in original code in red (if ,and ,progn, else) ;;<snippets>;; (if (and ;;<snippets>;; (setq pt (getpoint "\nSpecify dimension line location: ")) ;; ignore this line within 'and' ;;<snippets>;; ) (progn ;;add this as new (setq pts (mapcar '(lambda (x) (trans x 0 1)) pts) pt (gr-lines (vl-position *DimTypeBDA '("Horizontal" "Vertical" "Aligned")) 4 (getvar 'viewctr) pts ) ) ;setq (repeat (1- (length pts)) ;;<snippets>;; unchanged ) ;repeat ) ; end of progn (princ (strcat "\nError: Wrong selection of at least 2 BLOCKS.")) ;else ) ; end of if ;;<snippets>;; Edited May 5, 2020 by hanhphuc typo & trans 1 1 Quote
Ahmed_Hisham Posted May 5, 2020 Author Posted May 5, 2020 Hi @hanhphuc , Thank you for all your effort to solve it. Genius FH Final 5-5-2020.LSPFetching info... Quote
