Need help to set "rScale" variable between 0 and 1
How can I limit user to enter real number that greater 0 but less than or equal 1 ?
Quote
(setq rScale (getreal (strcat "\nEnter scale ratio: ")))
Thanks!
Edited by phuynh
One way.
(setq time t)
(while time
  (setq x (getreal "\nEnter value between 0.0 and 1.0:  "))
  (if (and (> x 0.0) (< x 1.0))
    (setq time nil)
Thank you for reply,
It 's work great!
Thanks,
Here's another... Not tested as it's typed away from CAD.
(while
    (null (< 0.0 (setq rScale (getreal "\nSpecify value: ")) 1.0))
    (princ "\nValue is not between 0 and 1")
I always like to give the user a way to exit without forcing an error with Esc, e.g.:
(while
    (and
        (setq x (getreal "\nSpecify a number between 0 and 1: "))
        (not (<= 0.0 x 1.0))
    (princ "\nNumber must be between 0 and 1.")
(if x
    ;; do stuff
Jonathan,
You code also work great!
Thanks!
Lee Mac,
I am big fan of you! and I learn lot from you and community.
I work on lisp code that set up axonometry (dimetric) view point in 3d space.
it is work but it sloppy, can you help?
Try this
;;Get a real number x lying the closed interval [a b]
;; (_getreal 0 1 0.5 "\nSpecify a number between 0 and 1 <0.5>: ")
;; (_getreal 0 1 nil "\nSpecify a number between 0 and 1: ")
(defun _getreal (a b default mesg / x)
;;  (if (not default) (initget 1)) ;;Optional
 (setq x (vl-catch-all-apply (function getreal) (list mesg)))
 (cond
  ( (and default (not (numberp x))) default) ;;<Enter>, <Space>, <Esc>
  ( (and default (numberp x) (or (< x a) (> x b))) (_getreal a b default mesg))
  ( (and
     (not default)
     (or (not (numberp x)) (and (numberp x) (or (< x a) (> x b))))
    (_getreal a b nil mesg)
  (T x)
) ;;_getreal
