MJLM Posted April 28, 2020 Posted April 28, 2020 In continuation of this thread I would like to continue this interesting story about UCSs and transformed entities. So far I have understood ( I am thankful to the community here) that An OCS is an coordinate system that most of the Autocad entities use instead of any other CS An OCS share the same origin with the WCS, however its x,y,z may be other than the one of the WCS However, it seems that something still eludes me and I cannot fully grasp it. I made a very simple model with a line drawn in WCS from 0,0,0 to 1,2,3. I would like to insert the same model on this one, that is having this line sitting on the end point (1,2,3) of the other as an extension. That means the lines need to be collinear. Let's assume I mirror3d this line on the xy plane, so the extrusion vector now becomes 0.0 0.0 -1.0. Using the following snippet the line comes on the correct placement but the orientation is wrong. What am I missing? ; clicking the mirrored entity from 0,0,0 to 1,2,-3 (setq pt (cdr (assoc 11 (setq ent (entget (car (entsel))))))) (setq v (cdr (assoc 210 ent))) ; inserting the drawing (entmakex (list (cons 0 "INSERT") (cons 2 "Dwg") (cons 8 "0") (cons 10 (trans (trans pt 0 1) 1 v)) (cons 70 0) (cons 66 1) (cons 50 0) (cons 210 v) ) ) Any suggestions appreciated. Quote
Lee Mac Posted April 28, 2020 Posted April 28, 2020 Lines are not planar entities, and therefore their endpoints are defined relative to the WCS and they do not uniquely define a plane, as such, the associated extrusion vector will be essentially arbitrary, and dependent upon the active UCS when the line was created. Quote
MJLM Posted April 28, 2020 Author Posted April 28, 2020 That only complicates things. I was under the impression that one inserted block could be placed per the state of an other object in the master drawing (location & orientation). On the other thread I posted above that worked. I just don't understand what's the difference. Quote
Lee Mac Posted April 28, 2020 Posted April 28, 2020 On 4/28/2020 at 4:59 PM, MJLM said: That only complicates things. I was under the impression that one inserted block could be placed per the state of an other object in the master drawing (location & orientation). On the other thread I posted above that worked. I just don't understand what's the difference. Expand It depends what the "other object" is - if such object is planar (e.g. arc, circle, 2D polyline, block reference etc.), then the block can be inserted to reside in the same plane as the existing object, however as noted above, a line on its own does not define a unique plane (observe that any plane can be rotated about the line) and so the plane in which the new block reference should reside is ambiguous. Quote
MJLM Posted April 28, 2020 Author Posted April 28, 2020 I guess I'm just looking for that one plane passing through the insertion point and being perpendicular to the transformed line (ie normal vector). I m investigating. I will come back on this. Quote
MJLM Posted May 4, 2020 Author Posted May 4, 2020 When inserting a block with (command-s "_.insert" path "_non" inspt 1.0 1.0 0.0) and trying to orient it with (entmod (subst nrv (assoc 210 ins_ent) ins_ent)) where nrv is the desired normal vector in form of (cons 210 '(i j k)) produces a wrong placement. When trying to translate it back to the correct location using (entmod (subst (trans inspt (cdr nrv) 1) (assoc 10 (entget (entlast))) (entget (entlast))) it simply does not work. What am I missing here? Quote
Lee Mac Posted May 4, 2020 Posted May 4, 2020 Since the insertion point is expressed relative to the OCS defined by the normal vector, you'll need to transform the insertion point to the OCS defined by the new normal, e.g.: (entmod (subst (cons 10 (trans (cdr (assoc 10 ins_ent)) (cdr (assoc 210 ins_ent)) (cdr nrv))) (assoc 10 ins_ent) (subst nrv (assoc 210 ins_ent) ins_ent) ) ) Quote
