Jonathan Handojo Posted May 3, 2020 Posted May 3, 2020 34 minutes ago, BIGAL said: "please give me codes." Sometimes if you keep adding then you may have to pay for service. I was kinda thinking about that too. Partly the reason I wasn't participating in the first place. @Praveen p, things don't just come for free. Learn for yourself and understand how AutoLISP works first before giving us orders. If you actually know how to do a few things for yourself, you might actually get what you're after before even posting here. If you're really stuck, only then seek for help. From what I've seen, it doesn't seem like you're putting effort into what you actually want to achieve and just "want codes for free"... Did you already try what @hanhphuc suggested... 7 hours ago, hanhphuc said: as i already mentioned :STRCAT have you tried it? once you understand the usage of the function, then you won't ask for help for the next 3rd , 4th etc. different block anymore .. learning is the key!! If you really want codes written specifically for you "in one program", feel free to hire someone to do it for you. Quote
Jonathan Handojo Posted May 3, 2020 Posted May 3, 2020 (edited) 13 hours ago, hanhphuc said: perhaps something LM:alpha++ ? (LM:alpha++ "AZ") ; BA (LM:num->col 1); A (LM:num->col 26); Z (LM:num->col 27); AA Well, that would fail if the number is too big... It's not practical, will most likely never get there but who knows. (LM:num->col 44781359266574102) where then the number is considered a real. ;; Number to Column - Lee Mac ;; Converts an integer into a column reference, e.g. 27 -> AA ;; n - [int] positive non-zero integer (defun LM:num->col ( n ) (if (< n 27) (chr (fix (+ 64 n))) ; <--- Just a slight touch there (strcat (LM:num->col (/ (1- n) 26)) (LM:num->col (1+ (rem (1- n) 26)))) ) ) Edited May 3, 2020 by Jonathan Handojo Quote
hanhphuc Posted May 3, 2020 Posted May 3, 2020 7 hours ago, BIGAL said: "please give me codes." Sometimes if you keep adding then you may have to pay for service. 6 hours ago, Jonathan Handojo said: If you really want codes written specifically for you "in one program", feel free to hire someone to do it for you. 4 hours ago, Jonathan Handojo said: Well, that would fail if the number is too big... It's not practical, will most likely never get there but who knows. IMO In most cases indexing never hits that big number eg: a worker manually 1"sec per point non stop, 60" x 60' x 8Hr = 28,800 points/day. ie: 1 year about 10mil points, the dwg also gets bloated 4 hours ago, Jonathan Handojo said: (LM:num->col 44781359266574102) where then the number is considered a real. nice! a REAL 44781359266574102 (LM:NUM->COL 44781359266574102) 1 LM:NUM->COL -> (LM:NUM->COL 44781359266574102 ) 2 LM:NUM->COL -> (LM:NUM->COL 1722359971791311 ) 3 LM:NUM->COL -> (LM:NUM->COL 66244614299665 ) 4 LM:NUM->COL -> (LM:NUM->COL 2547869780756 ) 5 LM:NUM->COL -> (LM:NUM->COL 97994991567 ) 6 LM:NUM->COL -> (LM:NUM->COL 3769038137 ) 7 LM:NUM->COL -> (LM:NUM->COL 144963005 ) 8 LM:NUM->COL -> (LM:NUM->COL 5575500 ) 9 LM:NUM->COL -> (LM:NUM->COL 214442 ) 10 LM:NUM->COL -> (LM:NUM->COL 8247 ) 11 LM:NUM->COL -> (LM:NUM->COL 317 ) 12 LM:NUM->COL -> (LM:NUM->COL 12 ) 12 LM:NUM->COL <- "L" 12 LM:NUM->COL -> (LM:NUM->COL 5 ) 12 LM:NUM->COL <- "E" 11 LM:NUM->COL <- "LE" 11 LM:NUM->COL -> (LM:NUM->COL 5 ) 11 LM:NUM->COL <- "E" 10 LM:NUM->COL <- "LEE" 10 LM:NUM->COL -> (LM:NUM->COL 20 ) 10 LM:NUM->COL <- "T" 9 LM:NUM->COL <- "LEET" 9 LM:NUM->COL -> (LM:NUM->COL 8 ) 9 LM:NUM->COL <- "H" 8 LM:NUM->COL <- "LEETH" 8 LM:NUM->COL -> (LM:NUM->COL 5 ) 8 LM:NUM->COL <- "E" 7 LM:NUM->COL <- "LEETHE" 7 LM:NUM->COL -> (LM:NUM->COL 7 ) 7 LM:NUM->COL <- "G" 6 LM:NUM->COL <- "LEETHEG" 6 LM:NUM->COL -> (LM:NUM->COL 5 ) 6 LM:NUM->COL <- "E" 5 LM:NUM->COL <- "LEETHEGE" 5 LM:NUM->COL -> (LM:NUM->COL 14 ) 5 LM:NUM->COL <- "N" 4 LM:NUM->COL <- "LEETHEGEN" 4 LM:NUM->COL -> (LM:NUM->COL 9 ) 4 LM:NUM->COL <- "I" 3 LM:NUM->COL <- "LEETHEGENI" 3 LM:NUM->COL -> (LM:NUM->COL 21 ) 3 LM:NUM->COL <- "U" 2 LM:NUM->COL <- "LEETHEGENIU" 2 LM:NUM->COL -> (LM:NUM->COL 19 ) 2 LM:NUM->COL <- "S" 1 LM:NUM->COL <- "LEETHEGENIUS" "LEETHEGENIUS" Quote
