Nested Rectangle block corner points coordinates
I want To extract Nested Rectangle block corner points coordinates
Find below imsge
  • Replies 22
  • Praveen p
    8
  • hanhphuc
    7
  • Jonathan Handojo
    4
  • BIGAL
    2
Posted Images
Need a dwg to look at task properly, if its the only pline in the block then easy.
I want to extract nested block coordinates by click the nested blick.
please give me lisp codes(hint)
please find the attachment dwg
nested block.dwg
No need to make new threads for the same question.
The attached drawing is not very helpful as the block is not nested. It would be easier if you provided a sample drawing of blocks where this block is nested.
Find below imsge
my $0.02
1.easiest way explode+ undo1, but useless if nested more than 1 level
2.Express Tool, command: NCOPY ,then get vertices (WCS coordinates) as usual
For Bricscad which no ET supported
(defun c:nestpl (/ np enx l)
  ;hanhphuc 01.05.2020
  ;for Bricscad
  ;uniform scale only & does not support dynamic block
  (setvar 'pdmode 2)
  (if
    (setq np (nentselp "\nSelect nested : "))
    (and
    (setq enx (entget (car np)))
    (or
    (= (cdr (assoc 0 enx)) "LWPOLYLINE")
    (alert "Invalid LWPolyline entity!")
    (setq l (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) enx)))
    (mapcar '(lambda (x) (entmakex (list '(0 . "POINT") (cons 10 x))))
      (if (= (length np) 4)
                     (apply
                       'mapcar
                       (cons
                         (cons
                           (mxv (caddr np) x)
                           (mapcar
                             '(lambda (x) (cdr (assoc 10 (entget x))))
                             (cadddr np)
                l
        l
    (princ "\nDone!")
  (progn (alert "Please pick LWPolyline!")
  (princ "\nhttps://www.cadtutor.net/forum/topic/70393-nested-rectangle-block-corner-points-coordinates/")
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
1 hour ago, hanhphuc said:
my $0.02
  ;for Bricscad
  (setvar 'pdmode 2)
  (if
    (and
    (or
                     (apply
                       'mapcar
                       (cons
                         (cons
                           (mxv (caddr np) x)
                           (mapcar
                             (cadddr np)
                l
        l
    (princ "\nDone!")
(defun mxv ( m v )
If rectangle is single line entity
How to insert points and  its serial number
Try to learn 🤔
you can add or modify anything you wanted in  (lambda (x) <where entmakex POINT resides>  )
Example 1: This will add incremental numbering start with "1"
(entmakex (list '(0 . "TEXT")(cons 10 x)(cons 40 (getvar 'textsize))(cons 1 (itoa (setq *index-num* (1+ (cond (*index-num*)(0)))) ))))
 use as 'x' as token (point coordinates)
 example 2: add circle
(command "CIRCLE" x 0.2)
do it yourself, trial and error see what happens :)
report back if error occurs good luck
Edited by hanhphuc
thank you sir
  Can you give this program without using mapcar AND lambda functions
18 hours ago, Praveen p said:
thank you sir
(defun c:ppp ( / pt size )
(setq size 1.0) ;;change text height here or (getvar 'textsize)
(while
(setq pt (getpoint "\nSpecify point or <Enter> to skip : ")) ;;variable 'pt' as token
;;; copied from previous, 'x' -> 'pt'
(entmakex (list '(0 . "TEXT")(cons 10 (trans pt 1 0))(cons 40 size)(cons 1 (itoa (setq *index-num* (1+ (cond (*index-num*)(0)))) ))))
Edited by hanhphuc
trans
thank you sir.
one more drawing attached to this mail.
please give me the codes for this drawing.
without using mapcar and lambda function give me the codes.
by click nested bock place the all point like shown in the drawing.
all codes must be in one program
SAMPLE.dwg
click & read this -> STRCAT
(setq *index-num* nil) ;; add this to initialize counting
before (1 . "1"
after (1 . "P-2";;prefix "P-" concatenation
(cons 1 (strcat "P-" (itoa (setq *index-num* (1+ (cond (*index-num*)(0)))) )))
thank you sir.
nested block is different with prvious block
in this drawing is different with previous drawing just check this drawing first sir.
text "p" is not constant some time it may be "A","B" TO "Z". AND some times text may be "A1",A2" OR "B1","B2"  so on
please give me full program without mapcar and lambda functions.
What's wrong with mapcar and lambda? They're very useful tools that even the most complex programs and codes use. I can almost bet that not even one of the LISP programs produced by the greatest programmers out there can exist without those. That's why they call it list processing.
Or is it because you don't actually know how they work and don't want them in there?
Why don't you describe the full situation that you actually want to achieve and post it at once instead of "P is not constant" or "here's one more dwg"? Otherwise the people who've helped you need to change their codes again and again.
sorry for that sir,
Actually i have different type of blocks,first block is different with second type of block first program codes not working on second block
so thats why i asking it.
please give me codes.
thank you .
2 hours ago, Praveen p said:
thank you sir.
perhaps something LM:alpha++  ?
(LM:alpha++ "AZ") ; BA
(LM:num->col 1); A
(LM:num->col 26); Z
(LM:num->col 27); AA
example: repeat 235 increment 1+
(setq prefix "" i -1)
(repeat	(1+ (* 9 26))
  (terpri)
  (princ
    (strcat (setq prefix (if (zerop (rem (setq i (1+ i)) 9))
			   (LM:alpha++ prefix)
			   prefix
	    "-"(itoa (1+ (rem i 9)))
output
A-1
A-2
A-3
A-4
A-5
A-6
A-7
A-8
A-9
B-1
B-2
B-3
B-4
B-5
B-6
B-7
B-8
B-9
C-1
C-2
C-3
C-4
C-5
C-6
C-7
C-8
C-9
D-1
D-2
D-3
D-4
D-5
D-6
D-7
D-8
D-9
E-1
E-2
E-3
E-4
E-5
E-6
E-7
E-8
E-9
F-1
F-2
F-3
F-4
F-5
F-6
F-7
F-8
F-9
G-1
G-2
G-3
G-4
G-5
G-6
G-7
G-8
G-9
H-1
H-2
H-3
H-4
H-5
H-6
H-7
H-8
H-9
I-1
I-2
I-3
I-4
I-5
I-6
I-7
I-8
I-9
J-1
J-2
J-3
J-4
J-5
J-6
J-7
J-8
J-9
K-1
K-2
K-3
K-4
K-5
K-6
K-7
K-8
K-9
L-1
L-2
L-3
L-4
L-5
L-6
L-7
L-8
L-9
M-1
M-2
M-3
M-4
M-5
M-6
M-7
M-8
M-9
N-1
N-2
N-3
N-4
N-5
N-6
N-7
N-8
N-9
O-1
O-2
O-3
O-4
O-5
O-6
O-7
O-8
O-9
P-1
P-2
P-3
P-4
P-5
P-6
P-7
P-8
P-9
Q-1
Q-2
Q-3
Q-4
Q-5
Q-6
Q-7
Q-8
Q-9
R-1
R-2
R-3
R-4
R-5
R-6
R-7
R-8
R-9
S-1
S-2
S-3
S-4
S-5
S-6
S-7
S-8
S-9
T-1
T-2
T-3
T-4
T-5
T-6
T-7
T-8
T-9
U-1
U-2
U-3
U-4
U-5
U-6
U-7
U-8
U-9
V-1
V-2
V-3
V-4
V-5
V-6
V-7
V-8
V-9
W-1
W-2
W-3
W-4
W-5
W-6
W-7
W-8
W-9
X-1
X-2
X-3
X-4
X-5
X-6
X-7
X-8
X-9
Y-1
Y-2
Y-3
Y-4
Y-5
Y-6
Y-7
Y-8
Y-9
Z-1
Z-2
Z-3
Z-4
Z-5
Z-6
Z-7
Z-8
Z-9
AA-1
and so on..
AA-9
AB-1
AB-9
AC-1
etc..
1 hour ago, Praveen p said:
sorry for that sir,
thank you .
as i already mentioned :
STRCAT
have you tried it?
once you understand the usage of the function, then you won't ask for help for the next 3rd , 4th etc. different block anymore .. :)
learning is the key!!
p/s: command BEDIT if there's only line entity you can command PEDIT select Multiple JOIN as LWPOLYLINE
then you can use LISP c:nestpl for the rest of blocks
Edited by hanhphuc
comment bedit
"please give me codes." Sometimes if you keep adding then you may have to pay for service.
