hosneyalaa Posted June 25, 2021 Share Posted June 25, 2021 On 6/22/2021 at 7:47 PM, jbach said: Here you go. Yes they are COGO points and they are unlocked when trying to move with the LISP. Thank you! Moving Points.dwg 1.95 MB · 7 downloads For civil 3d form https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190 Quote Link to comment Share on other sites More sharing options...
Marcelo Seipke Posted February 1, 2023 Share Posted February 1, 2023 On 5/6/2020 at 4:56 PM, ronjonp said: is it posible to update this code work with Alignment PI ? Thanks (defun c:s2o (/ a b c d el m s) ;; RJP » 2020-04-29 ;; Could give bad results for multiple vertices that are within the 'search distance' (cond ((and (setq d (getdist "\nPick a distance to search: ")) (setq s (ssget ":L" (list '(0 . "CIRCLE,INSERT,POINT,LWPOLYLINE")))) ) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (= "LWPOLYLINE" (cdr (assoc 0 (setq el (entget e))))) (setq b (cons (vl-remove-if '(lambda (x) (/= 10 (car x))) el) b)) (setq a (cons (list (cdr (assoc 10 el)) e) a)) ) ) (if (setq b (mapcar 'cdr (apply 'append b))) (foreach p a (setq c (mapcar '+ (car p) '(0 0))) (cond ((setq m (vl-some '(lambda (x) (if (equal c x d) x ) ) b ) ) (setq b (vl-remove m b)) (entmod (append (entget (cadr p)) (list (cons 10 (append m (list (last (car p)))))))) ) ) ) ) ) ) (princ) ) On 5/6/2020 at 4:56 PM, ronjonp said: Yup. (defun c:s2o (/ a b c d el m s) ;; RJP » 2020-04-29 ;; Could give bad results for multiple vertices that are within the 'search distance' (cond ((and (setq d (getdist "\nPick a distance to search: ")) (setq s (ssget ":L" (list '(0 . "CIRCLE,INSERT,POINT,LWPOLYLINE")))) ) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (= "LWPOLYLINE" (cdr (assoc 0 (setq el (entget e))))) (setq b (cons (vl-remove-if '(lambda (x) (/= 10 (car x))) el) b)) (setq a (cons (list (cdr (assoc 10 el)) e) a)) ) ) (if (setq b (mapcar 'cdr (apply 'append b))) (foreach p a (setq c (mapcar '+ (car p) '(0 0))) (cond ((setq m (vl-some '(lambda (x) (if (equal c x d) x ) ) b ) ) (setq b (vl-remove m b)) (entmod (append (entget (cadr p)) (list (cons 10 (append m (list (last (car p)))))))) ) ) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
