Work planes aren't behaving as expected
I've set up a couple of work planes to make drafting on slanted surfaces easier, but it's not bahaving like I expected. I've made one work plane follow a sloping ceiling so that when I draw a pipe run in plan view it will follow the slope instead of the level - but that's not happening. It just follows the level as normal. If I try it in a section it works with line work, but not with pipes. Maybe I've misunderstood the whole concept?
Please explain "pipe" a 3d solid ?
Edited by BIGAL
Yes, 3D element. But could just as well be a duct, cable tray, etc.
  • 2 weeks later...
Can pipes be hosted to workplanes?
Did you set the workplane as current?
Why not use sloped pipe?
I don't know. I thought everything modeled in a given view would follow the current work plane for that view. Not true?
Yup.
I can, but to adjust sloped pipes later on if needed is sometimes a pain. Would be so much easier if I could draw them "flat" on a sloped work plane instead.
This won't work and I believe it's because pipes are not workplane based. You can't host one to a workplane. I tried aligning and locking a pipe to one and the lock did not hold when rotating the workplane.
So, it looks like if you want to draw sloped pipe in a plan view you need to draw sloped pipe as you normally would. I think if you are following a ceiling that you are much better off in a section view anyway, unless you know the slope.
