cat3appr Posted April 26, 2020 Posted April 26, 2020 Hello, How do I transform a geographical coordinate from Clarke 1866 to WGS84? Do we have this tool in autoCAD MAP? many thanks! Quote
Murph_map Posted May 4, 2020 Posted May 4, 2020 Make sure the dwg has the Clarke 1866 CS assigned to it, save it and close, then in a new dwg assign the correct WGS84 CS you need and map attach the original dwg then query in all. Quote
