ActiveX Inquiry
ojacomarket
I have to investigate the BlockReference properties in order to find those constants, which I could use later in other drawings also, but got only that "????????????"
Could you have an idea, friends?
(setq p1 (vlax-ename->vla-object (car (entsel))))
(setq p2 (vla-getattributes p1))
(setq p3 (vlax-safearray->list (vlax-variant-value p2)))
					Returns>>
#<VLA-OBJECT IAcadBlockReference 0000025e15206e28>
_$
#<variant 8201 ...>
_$
ActiveX Server returned an error: ???????? ??????
(setq p3 (vlax-invoke p1 'GetAttributes))
And if your block has attribute(s), it will return a list of all the VLA-Object representing each attribute of the selected block, including its tag name, text string, etc...
But if the object you select at p1 doesn't have the GetAttributes method, then the above will fail because you're trying to invoke a method on an object that doesn't actually support that method. You can find out what methods are supported for a object by using vlax-dump-object... For example:
(vlax-dump-object (vlax-ename->vla-object (car (entsel))) T)
And all the properties and methods will be printed into the console.
Edited by Jonathan Handojo
  • Thanks 1
_$
nil
_$
Returns nil... but how could it be possible, the block exists and could be inserted into drawing, but has no attributes to inspect wtf.:/
Is it somehow related to "reactors" or something like this..?
Edited by ojacomarket
1 minute ago, ojacomarket said:
_$
nil
_$
Well, do you know what block attributes are in the first place?
Or actually, if you want to inspect the properties of that block, simply use (vla-get- followed by the property you want to inspect.
For example, a block has an insertion point and effective name, so you can do (vla-get-InsertionPoint p1) or (vla-get-EffectiveName p1). When you inspect the VLA block, you get a full list of properties you want to get.
  • Thanks 1
Methods supported:
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   ConvertToAnonymousBlock ()
;   ConvertToStaticBlock (1)
;   Copy ()
;   Delete ()
;   Explode ()
;  							>>>>>>>>>>. GetAttributes () <<<<<<<<<<<<<
;   GetBoundingBox (2)
;   GetConstantAttributes ()
;   GetDynamicBlockProperties ()
;   GetExtensionDictionary ()
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   ResetBlock ()
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetXData (2)
;   TransformBy (1)
;   Update ()
Not it doesn't..
So how could I relate to my blockreferenced, I only expected via GetAttributes..
					Returns>>
_$
#<variant 8201 ...>
_$
What constants are you referring to?
Maybe not good expressed on a Lisp language :)
I meant that I would like to find those values of BlockReferenced objects, that will not change from drawing to drawing and,
        consequently, which I could reffer to my block in another drawings and CAD sessions
Because as it shows before, just reffering to (0 . "INSERT") type won't draw me desired block on my NEW drawing session
12 minutes ago, ojacomarket said:
Methods supported:
;   ArrayPolar (3)
;   Copy ()
;   Delete ()
;   Explode ()
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   ResetBlock ()
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetXData (2)
;   TransformBy (1)
;   Update ()
Not it doesn't..
You can only invoke a method if it pertains to the block. i.e. It has attributes.
You should use
(if (= :vlax-true (vlax-get-property p1 'hasattributes)) (setq p3 (vlax-invoke p1 'getattributes)))
You expect to (entsel) from the current drawing and get attributes from the same block from another drawing? How's that gonna work?
I mean it's not impossible, can be done using DBX.
I mean it's not impossible, can be done using ARX.
The only way is to invoke "Open drawing, that contain desired block" and then apply it into new drawing session?
My point was that, I could use BlockReferenced data from another drawing (template), since it couldn't be done from simple (entmake (cons 0 "INSERT"))
But I have to somehow store those Attributes of this block and then in the new drawing I could connect it, like to you use same function ENTMAKE to place this block on desired place of drawing, if got me..I hope :DD
Linking to other drawings is possible, but not as simple as just an entmake function.
Maybe this will tell you how much effort is put to access drawings from another drawing. Purge the current block first in the current drawing though.
  • Thanks 1
  • SLW210 changed the title to ActiveX Inquiry
If its a case of say getting attributes in simple method 2 lisps but ran individually.
ran in 1st dwg dump atts -> text file
ran in 2nd dwg Get atts -> text file
Why not just copy and paste between the 2 dwgs no code required.
  • Thanks 1
Thanks for response, I got you idea!
1. It takes time to copy and paste (even if it is couple secs)
2. If I have many objects on drawing, that require to place a block on it, I find it too boring to place every block on right position, rather I use code to place them automatically
1 hour ago, BIGAL said:
Look into palettes and that may help, or a library of block dwgs the when you do a insert it will be based around a known insert point.
By now, I have an idea, how to extract those properties, but cannot bound them, I had a proper look at Lee Mac code, but won't copy that, cuz insterested also in programming hah.
So i downloaded the AutoCAD: Bible by David M.Stein, I hope I got an idea from this book, how to bound complicated functions and use them.
As always, thank you for the feedbacks and comments, appreciate!
