Passward
Dayananda
On 4/18/2020 at 12:22 PM, Dayananda said:
This need to run with Mac. OS also.
since you are coder, my $0.05 optimization.
when prompt password, it would be friendlier if user gets notified [Caps-Lock ON/OFF]
1.Easy: Echo to the the screen entmake Text dynamic entmod. (advance may consider - Textbox , GrText or Textmask )
2.Advanced: create Attributed block update value
3.Expert: If MacOS supports Actable? emulate table as dialog box, column width=row height as Grid, customize merge cell as edit cell & buttoms. hittest
4.or slide vector image?
as participant, i personal vote for Lee's because bonus [<--Backspace] compatibility & excludes includes loop for [Function] keys.👍
though just minor spacer bug. (to replicate, just key-in all spaces then Backspace. notice the pipe "|" walks away)
p/s: Ron's dcl is more practical but excluded due to OP's query w/o DCL :)
v1.1 revision
;backspace
;expr - quoted list expression for additional functionality use 'STR' as token
;example: you make a fake dialog box using attributed block, Tag name is "KEY",
;you use your-att-func which can replace or vla-put-textstring the token 'STR'
;(foo "•" 20 '(your-att-func blk (list (cons "KEY" (strcat (substr STR 10) "|")))) )
;for normal usage just put nil for expression
;(foo (chr 149) 20 nil)
(defun foo ($ n expr / l k str x)
  ;;hp:pword 16.04.2020
  (terpri)
  (princ (setq x t
               str "Password: "
               ! str
  (while (and x (setq k (grread nil)))
    (if (and (= (car k) 2)
             (numberp (setq x (cadr k)))
             (or (= 8 x) (<= 32 x 127)) ;;
             (< (length l) n)
        (princ
          (strcat "\r"
                  (setq str
                    (if (= x 8)
                      (if (> (strlen str) (strlen !))
                        (substr str 1 (1- (strlen str)))
                      (strcat str $)
        (setq l (if (= x 8)
                  (if (> (length l) 0)
                    (cdr l)
                    l
                  (cons x l)
    (eval expr)
      (setq x nil)
  (vl-list->string (reverse l))
Edited by hanhphuc
code updated backspace, expr & allow space
  • Thanks 1
For any of you have to remember DOS you take your password test code and add it to the start of a lisp file saving into another directory then turn into fas or VLX this is super fast for 100's of files.
make a bat filecopy
copy c:\mydirectory\lips\password.lsp+c:\mydirectory\lips\file1.lsp c:\mydirectory\lips\tobecomp\file1.lsp
copy c:\mydirectory\lips\password.lsp+c:\mydirectory\lips\file2.lsp c:\mydirectory\lips\tobecomp\file2.lsp
copy c:\mydirectory\lips\password.lsp+c:\mydirectory\lips\file3.lsp c:\mydirectory\lips\tobecomp\file3.lsp
make a bat filecopy
with VLISP
vl-file-copy & vl-directory-files but avoid large file
(foo "c:\\mydirectory\\lips\\password.lsp"  ;;header file
"*.lsp" ;;pattern
"c:\\mydirectory\\lips\\" ;;source path
"c:\\mydirectory\\lips\\tobecomp\\" ) ;;destination path
(defun foo (Header Ext SPath DPath / new fname)
  ;;addheader - hp 21.04.2020
  (and
    (findfile header)
    (foreach fname (vl-directory-files SPath ext)
      (if (<= (vl-file-size fname) 10000)
	  (vl-file-copy
	    header
	    (setq new (strcat DPath
			      (if (= SPath DPath)
				"x"
			      fname
	  (vl-file-copy
	    (strcat SPath fname)
	    new
	    T
	  (princ (strcat "\n" new))
example
  (if
    (setq ext  "*.txt"
	  path (strcat (getenv "userprofile") "\\Downloads\\")
	  password (getfiled "Select password header file " path "txt" 16)
     (foo password ext path path)
@Dayananda sample attributed
Bcad PassWin7.dwg
Block name PASSWIN7
Tag name KEY = password
Tag name USER = Header
insert at viewctr
try -> attributes library
token= 'STR'
Edited by hanhphuc
Nice one Hahnphuc will definitely keep will add to my compile lisp.
