Not sure what i have been missing here. But finally decided to do something about our custom code.
The lisp looks for a file and if present on system proceeds to step 2.
Step 2 it checks for match with path.
this is where i get confused.. I thought a (princ) close's the file clean (no loose ends)
however the settings are there (in the options) but not applied.
what am I missing? I have looked for some way to apply settings under the options dialog but no success.
(Setvar "cmdecho" 0)
(if (= "24.0s (LMS Tech)" (getvar "ACADVER"))
		(if (not (wcmatch (getenv "PrinterConfigDir") "*path*"))									;Looking for Printer Configuration Search Path
		(setenv "PrinterConfigDir" "path")															;If not found add Printer Configuration Search Path
		(if (not (wcmatch (getenv "PrinterDescDir") "*path*"))
		(setenv "PrinterDescDir" "path")															;If not found add Printer Description Search Path
		(if (not (wcmatch (getenv "PrinterStyleSheetDir") "*path*"))								;Looking for Path in Plot Style Table Search Path
		(setenv "PrinterStyleSheetDir" "path;")														;If not found add Plot Style Table Search Path
;(alert "message")
(Setvar "cmdecho" 1)
Hopefully it does not work as this:
Is not setting the directory to an actual path. 😬
"PATH" most likely needs to be PATH .. post more of your code.
Edited by ronjonp
If i remove the ; after path everything seams to work now.
I was using the Quotes due to spacing in the path name.
Spacing in the path name
(setq path "x:\\my tempwork\\is here now\\not over there")
I don't understand how that code can work PATH /= "PATH".
Graphic to help you understand:
Edited by ronjonp
  • Like 2
;;; Comments list Ver1.0 10-07-15 Inital update
		(if (not (wcmatch (getenv "PrinterConfigDir") "*K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_Plotters*"))			;Looking for Printer Configuration Search Path
		(setenv "PrinterConfigDir" "K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_Plotters")									;If not found add Printer Configuration Search Path
		(if (not (wcmatch (getenv "PrinterDescDir") "*K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_PMP*"))
		(setenv "PrinterDescDir" "K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_PMP")											;If not found add Printer Description Search Path
		(if (not (wcmatch (getenv "PrinterStyleSheetDir") "*K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_Plotstyles*"))		;Looking for Path in Plot Style Table Search Path
		(setenv "PrinterStyleSheetDir" "K:\\Masters\\LOOK HERE\\Another FOLDER\\Company_Plotstyles")							;If not found add Plot Style Table Search Path
This should help
This should help
Be careful when checking with WCMATCH .. it is case sensitive 😉 .. here's another approach using FOREACH .. not tested.
;; cmedecho not needed for this code
;; (setvar "cmdecho" 0)
;; Set common path
(setq path "K:\\Masters\\LOOK HERE\\Another FOLDER\\")
  (foreach dir '(("PrinterConfigDir" "Company_Plotters")
		 (("PrinterDescDir" "Company_PMP"))
		 (("PrinterStyleSheetDir" "Company_Plotstyles"))
    ;; Added strcase for the wcmatch check
    (or	(wcmatch (strcase (getenv (car dir)))
		 (strcat "*" (setq a (strcase (strcat path (cadr dir)))) "*")
	;; Beware this will remove any other paths set .. this what you want?
	(setenv (car dir) a)
  (progn)
;; (setvar "cmdecho" 1)
Edited by ronjonp
