(findfile) not working as expected
So I have this weird situation.  In a list I have the following line
(findfile "C:\\Windows\\Fonts\\arial.ttf")
It returns "nil" on my home computer but it returns the path on my work computer.  It's a standard font, but I did make sure it is installed on both computers. I have no idea why it can't find the file on my home desktop.
I thought it could be permission thing because looking for files in the root directory, but I can find other files in the Windows folder.  I don't know what I'm doing wrong.
This  happens on ACAD 2020 and ACAD2021
Edited by guitarguy1685
hi,
not sure this alternative working?
;(defun _findfile (fn)
;  (if ((lambda (l) (vl-directory-files (car l)
;	     (apply 'strcat (cdr l))
;	 (fnsplitl fn)
;    fn
;;if findfile null , attempt to search local directory
;;"c:\\windows\\" ---> "C:\\Users\\user\\AppData\\Local\\Microsoft\\Windows\\"
  (cond
    ;; search as "C:\\windows\\Fonts\\arial.ttf"
    ((findfile fn))
    ;; search local as "C:\\Users\\user\\AppData\\Local\\Microsoft\\Windows\\fonts\\arial.ttf"
    ((findfile
       (strcat (getenv "userprofile")
	       "\\AppData\\Local\\Microsoft\\Windows\\"
	       (vl-string-left-trim "c:\\windows" (strcase fn t))
    ;; search in ACAD directory only as "arial.ttf"
    ((findfile (vl-string-left-trim
		 (vl-filename-directory
		   fn
		 fn
try
( _findfile "C:\\Windows\\Fonts\\arial.ttf" )
Edited by hanhphuc
findfile local sorted by OP
Did you check that the 'arial.ttf' file is in that location?
Okay so it appears to be a windows thing. When I go to C:\Windows\Fonts, Windows10  uses some "font display window", different from file explorer.  On both computers the font shows that Arial is installed.
However if I use UNC convention to view the folder such as "\\computer-name\C$\Windows\Fonts" i can view the folder in a standard file explorer view.  When I do this, I only see the arial.ttf on my work station and not my home desktop.  So while Arial is installed on my home desktop the file is somewhere else. I'll find it.
So the (findfile) is working as it should.
I found it.  This font is installed on my user folder.  %userprofile%\AppData\Local\Microsoft\Windows\Fonts
I didn't know that was a thing.
Glad you got it sorted! 👍
8 hours ago, hanhphuc said:
I completely glossed over the fact that your solution includes searches in user profile and root directory. That would've solved my issue.
hi,
;	 (fnsplitl fn)
;    fn
  (cond
    ((findfile fn))
    ((findfile
		   fn
		 fn
try
The following should present a far more reliable method across multiple systems:
(defun LM:findfontfile ( fnt / dir )
    (if (setq dir (LM:specialfolder "fonts"))
            (eval
                (list 'defun 'LM:findfontfile '( fnt )
                    (list 'findfile
                        (list 'strcat
                            (vl-string-right-trim "\\"
                                (vl-string-translate "/" "\\" dir)
                            "\\" 'fnt
            (LM:findfontfile fnt)
;; Special Folder  -  Lee Mac
;; Queries the WshSpecialFolders collection for the specified folder
;; Ref: http://msdn.microsoft.com/en-us/library/9x9e7edx%28v=vs.85%29.aspx
(defun LM:specialfolder ( fld / rtn spf wsh )
    (if (setq wsh (vlax-get-or-create-object "wscript.shell"))
            (setq rtn
                (vl-catch-all-apply
                   '(lambda ( )
                        (setq spf (vlax-get-property wsh 'specialfolders))
                        (vlax-invoke-method spf 'item fld)
            (if spf (vlax-release-object spf))
            (vlax-release-object wsh)
            (if (not (vl-catch-all-error-p rtn)) rtn)
(vl-load-com) (princ)
_$ (LM:findfontfile "arial.ttf")
  • Like 3
works like a charm. thanks lee-mac
