vsmax vsmin
Hi me again..
This snippet used for ssget "C" or "W" (crossing/window)
(defun c:test (/ l x y)
(setq l (mapcar '(lambda (x)
                           (setq x (getvar x))
                     (if
                       (listp x)
                       (trans x 1 2)
                       x
                  '(viewsize viewctr vsmax vsmin)
        x (* 0.5
             (car l)
             (apply '/
                    (vl-remove 0.0 (apply 'mapcar (cons '- (cddr l))))
        y (* (car l) 0.5)
  (entmakex
  (cons
    '(0 . "LINE")
    (mapcar
      '(lambda (f i)
	 (cons
	   i
	   (mapcar '(lambda (a b c) ((eval a) b c)) f (cadr l) (list x y))
      '(10 11)
entmake line for visibility showing 2 corners connected.
it should look like screenshot (ps or ms)
Autocad has no issue
can you report your vsmin vsmax in new dwg or any dwg (Bricscad)?
thanks!
