hanhphuc Posted April 4, 2020 Posted April 4, 2020 (edited) hi guys i have a FIELD expression working fine in AC2007 old 32bit desktop LINE's delta properties= x,y multiply scale factor eg: 0.03,-0.04 x 1000, then entmake MTEXT should display dX=30 dY=-40 but it's weird, Bricscad/v19/win7 x64 (sorry as i'm newbie)dX %<cExpr (1000 * %<cObjProp Object(%<\_ObjId 1889532720>%).Delta after double click to edit it becamedX %<\_FldIdx 0a(if ACAD double click to edit FIELD, a dialog pops up, you can check formula 1000 * 0.030 & preview) can you replicate this bug?? (defun foo (obj x) (apply 'strcat (mapcar '(lambda (a b) (strcat a "%<\\AcExpr (" (rtos (float x) 2 0) " * %<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid obj)) ">%).Delta \\f \"%lu2%pt" b "%pr8\">%" ") \\f \"%lu2%pt" b "%qf1%pr0\">%" " \n" ) ) '("dX " "dY ") '("1" "2") ) ) ) test delta x=0.03 y=-0.04 (and (setq pt (getpoint "\nSpecify point.. ")) (setq en (entmakex (cons '(0 . "LINE") (mapcar '(lambda (a b) (cons a (mapcar '+ pt b)) ) '(10 11) '((0. 0.) (0.03 -0.04)) ) ) ) ) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") (cons 40 (getvar 'textsize)) (cons 10 pt) (cons 1 (foo (vlax-ename->vla-object en) 1000.) )) ) ) need some comparison eg: xxxcad/20xx/winxxdX ? ? ? ? dY ? ? ? ? or something else? if there's bug, any solution? thanks Edited April 4, 2020 by hanhphuc Quote
BIGAL Posted April 6, 2020 Posted April 6, 2020 (edited) Not sure but dX %<cExpr (1000 * %<cObjProp Object(%<\_ObjId 1889532720>%).Delta 2 x (( only 1 ) Edited April 6, 2020 by BIGAL Quote
hanhphuc Posted April 9, 2020 Author Posted April 9, 2020 On 4/6/2020 at 9:08 AM, BIGAL said: Not sure but dX %<cExpr (1000 * %<cObjProp Object(%<\_ObjId 1889532720>%).Delta 2 x (( only 1 ) @BIGAL further discussions, here.. Quote
