jim78b Posted April 3, 2020 Share Posted April 3, 2020 i don't know after i work with a 3d drawings savings become very slowly, i must resave in other new drawing copy and paste all objects, why? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 3, 2020 Share Posted April 3, 2020 Did you try -PURGE the drawing? That is basically what Copy and Paste are doing. You may also want to run an AUDIT every once in a while. Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 3, 2020 Author Share Posted April 3, 2020 Yes try -purge and regapps...i have autocad mech 2013 i suppose for this ?if i use aectoacad...it export to dwg and i find various layers with name :aecobjectexplode Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 3, 2020 Share Posted April 3, 2020 What are you computer specs? What other programs are running in the background? Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 3, 2020 Author Share Posted April 3, 2020 win7 64 bit 16 giga ram intel core 7 nvidia quadro k600 autocad mech 2013 win7 64 bit 16 giga ram intel core 7 nvidia quadro k600 hard disk ssd autocad mech 2013 no other programs except dropbox but i don't share or backup any files in dropbox all i saved local. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 3, 2020 Share Posted April 3, 2020 Do you have all the updates and latest drivers? What did AUDIT report? Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 3, 2020 Author Share Posted April 3, 2020 (edited) yes of course latest nvidia driver, service pack sp2 autodesk. audit tell me that dwg is correct but after some works the drawing slow down. Edited April 3, 2020 by jim78b Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 3, 2020 Author Share Posted April 3, 2020 i attach my dwg new_block.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 6, 2020 Share Posted April 6, 2020 I purged the drawing and it went to less than 1.5 MB. Seems to be an AutoCAD Mechanical issue looking at the results. Quote -PURGE Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]: a 2 zero-length geometric objects deleted. Enter name(s) to purge <*>: Verify each name to be purged? [Yes/No] <Y>: n Deleting block "GENAXEH". 1 block deleted. Deleting layer "Defpoints". 1 layer deleted. Deleting linetype "ACISOTGB". Deleting linetype "ACISOTGL". Deleting linetype "ACISOWELD". Deleting linetype "AM_ISO02W050". Deleting linetype "AM_ISO02W050x2". Deleting linetype "AM_ISO08W050". Deleting linetype "AM_ISO08W050x2". Deleting linetype "AM_ISO09W050". Deleting linetype "Amconstr". Deleting linetype "Amzigzag". Deleting linetype "CENTER". Deleting linetype "HIDDEN". Deleting linetype "PHANTOM2". 13 linetypes deleted. Deleting text style "ACISOGDT". Deleting text style "ACISOTS". 2 text styles deleted. Deleting shape file "genltshp.shx". 1 shape file deleted. Deleting dimension style "AM_ISO Layout". Deleting dimension style "AM_ISO$0". Deleting dimension style "AM_ISO$2". Deleting dimension style "AM_ISO$3". Deleting dimension style "AM_ISO$4". Deleting dimension style "AM_ISO$6". Deleting dimension style "AM_ISO$7". Deleting dimension style "AM_ISO$SF". Deleting dimension style "AM_ISO$SH". 9 dimension styles deleted. No unreferenced mlinestyles found. No unreferenced plotstyles found. No unreferenced table styles found. No unreferenced materials found. No unreferenced visual styles found. No unreferenced multileader styles found. No unreferenced groups found. No unreferenced Detail view styles found. No unreferenced Section view styles found. Command: -PURGE Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]: r Enter name(s) to purge <*>: Verify each name to be purged? [Yes/No] <Y>: n Deleting registered application "ACAD_DSTYLE_DIMANGULAR_EXTENSION". Deleting registered application "ACAD_DSTYLE_DIMARC_LENGTH_SYMBOL". Deleting registered application "ACAD_DSTYLE_DIMINSPECT". Deleting registered application "ACAD_DSTYLE_DIMJOGGED_JOGANGLE_SYMBOL". Deleting registered application "ACAD_DSTYLE_DIMRADIAL_EXTENSION". Deleting registered application "ACAD_EXEMPT_FROM_CAD_STANDARDS". Deleting registered application "ACAD_MLEADERVER". Deleting registered application "ACAD_OBJECT_CHANGE_GUID". Deleting registered application "ACAD_TEMP_GRAPHIC". Deleting registered application "AcadAnnoPO". Deleting registered application "AcadAnnotative". Deleting registered application "ACADM_DIM_EDIT". Deleting registered application "AcAecLayerStandard". Deleting registered application "ACATTRIBSERVICES". Deleting registered application "ACM_PP_ASSOCVAR". Deleting registered application "ACM_PP_DIM_ACTION_MACRO". Deleting registered application "ACM_PP_DIM_CONSTRAINT". Deleting registered application "ACM_PP_DIM_CONSTRAINT_DRAG_GRIP". Deleting registered application "AD_DRAW". Deleting registered application "AMDT_DM_ADJ". Deleting registered application "DCO15". Deleting registered application "DESIGNERASSEMBLIES". Deleting registered application "GENIUS_AMGTXT_16". Deleting registered application "GENIUS_GENBH_13". Deleting registered application "GENIUS_GENCEN_19". Deleting registered application "GENIUS_GENDTOL_13". Deleting registered application "GENIUS_GENHATCH_13". Deleting registered application "GENIUS_GENOBJ-N-CEN_13". Deleting registered application "GENIUS_GENOBJ-N-HTC_13". Deleting registered application "GENIUS_GENOBJ-N-SDF_13". Deleting registered application "GENIUS_GENOBJ-N-ZOO_13". Deleting registered application "GENIUS_GENOBJ-NBEHI-BHB_13". Deleting registered application "GENIUS_GENOBJ-NBEHI-BHF_13". Deleting registered application "GENIUS_GENOENT_13". Deleting registered application "GENIUS_GENOLIS_13". Deleting registered application "GENIUS_GENOREF_13". Deleting registered application "GENIUS_GENSCREG_15". Deleting registered application "GENIUS_GENZOO_17". Deleting registered application "GEVID1566572766". Deleting registered application "GEVID1566572768". Deleting registered application "MCAD_NO_VIS". 41 registered applications deleted. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 6, 2020 Share Posted April 6, 2020 Thread moved to Mechanical & MDT Forum. Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 6, 2020 Author Share Posted April 6, 2020 Wow thanks for saw drawing !does autocad mech the cause ? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 7, 2020 Share Posted April 7, 2020 Maybe, not sure what that Genius stuff is from. I did several things to your drawing and saved and saved and saved some more in AutoCAD 2018 and sized stayed pretty much the same. Maybe someone else with more time can dig deeper for you. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 7, 2020 Share Posted April 7, 2020 Okay, so that is AutoCAD Mechanical as well. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-remove-the-GENAXEH-block-from-an-AutoCAD-Mechanical-drawing.html 1 Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 7, 2020 Author Share Posted April 7, 2020 (edited) thanks very much you are a genius! thanks to all !!! but is this the cause of slow savings? Edited April 7, 2020 by jim78b Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 7, 2020 Share Posted April 7, 2020 Like I stated, no slow saves on my computer with AutoCAD 2018 (that's even with me remoted into the computer at work), so I would say that it is an AutoCAD Mechanical issue and/or an issue with your computer, possibly some settings. I used to avoid using any Mechanical specific things unless needed, way back when I used Mechanical, though I don't recall any problems, but it has been a while. Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 8, 2020 Author Share Posted April 8, 2020 Ok thanks i use mech 2013 and i am Tired of use it because has a lot of bugs. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 8, 2020 Share Posted April 8, 2020 I do believe you can just use the Core AutoCAD part. You might head over to the Autodesk AutoCAD Mechanical Forums and see if that is a common or at least solved issue or some work arounds available. But, yes an upgrade may help. Quote Link to comment Share on other sites More sharing options...
jim78b Posted April 8, 2020 Author Share Posted April 8, 2020 yes understand however thanks a lot Quote Link to comment Share on other sites More sharing options...
