Hi guys,
Can someone explain the result behind (eq '(1 2) '(1 2))?
I've been using the eq function quite a while and just found this out.
I can very well use equal, but this just rings a concern.
Thanks,
Jonathan Handojo
(equal '(1 2) '( 1 2))
like this ??
This will give you a hint
(setq a '(1 2) b a)
(eq a b) => T
(setq a '(1 2) b a)
(eq a b) => T
Man that's weird... I mean normally if you want to compare between two lists, they are in most cases not gonna be in that form.
You normally have a list coming from one evaluation, and another list that evaluates to the exact same list (in my case, it's a list of strings) from another evaluation. Then when I run (eq a b), it evaluates to nil
basically with lists (eq ...) tests if they are bound to the same object/entity. Same applies to (= ..). However  (equal ...) tests if they evaluate to the same thing.
Edited by dlanorh
be careful
(setq a '(1 2) b a c a)
(eq a '(1 2) )
;nil
(eq a b)
;T
(equal '(1 2) a )
;T
(= '(1 2) a b)
;nil
(= a b c)
;T
Edited by hanhphuc
Jon's dizziness so '(1 2 3) -> '(1 2)
  • Confused 1
Makes sense now, although (eq 2 2) or (eq "str" "str") returns T.
2 hours ago, hanhphuc said:
be careful
(setq a '(1 2 3) b a c a)
(eq a '(1 2 3) )
;nil
(eq a b)
;T
(equal '(1 2 3) a )
;T
(= '(1 2 3) a b)
;nil
(= a b c)
;T
Oh, please don't make me any dizzier than I already am 🤣
  • Funny 1
I know, but 2, "str"  and any real numbers are not lists and so are evaluated.
(eq expression 1 expression 2)
It mainly determines whether the two expressions have the same constraint conditions (whether Expression 1 and Expression 2 are set to the same object.
(setq f1 '(a b c) f2 '(a b c))
(setq f3 f2)
(eq f1 f2)   ;---->nil ,Because f1 and f2 have the same value, they do not point to the same list
(eq f3 f2)   ;---->T,Because f3 and f2 point to the same list
So I will tell you this, you should be able to understand it. In the case of not sure whether it is the same table, I generally use (equal expression 1 expression 2 [FUZZ])
