Hi all guys,
I need a function to find the point that has minimum Y in a list, like this :
((10 15) (19 25) (26 10) (50 32))
>> (26 10)
Can some one give me a function or best way to do this?
Thanks in advanced.
Edited by amir0914
Try. I can't test as I'm away from AutoCAD
(defun miny (lst) (car (vl-sort lst '(lambda (x y) (< (cadr x) (cadr y))))))
;example call (setq ymin (miny '((10 15) (19 25) (26 10) (50 32))))
When finding extrema, it is typically more efficient to iterate over the list once, rather than using a sorting function (such as vl-sort) which necessarily performs many more comparisons to order the entire list - this is one circumstance where shorter code is not necessarily more efficient. You may find this thread of interest in this regard.
2 hours ago, amir0914 said:
Quote
Hi all guys,
>> (26 10)
Thanks in advanced.
I won't probably iterate. I'll do the below, though I'm not sure if it's more efficient:
(defun findmin (lst / m)
  (setq m (apply 'min (mapcar 'cadr lst)))
  (car (vl-member-if '(lambda (x) (eq (cadr x) m)) lst))
You are right lee mac, I looked at the post that you implied. it's the exact post that i need.
(defun car-sort ( l f / removenth r k )
  (defun removenth ( l n / k )
    (setq k -1)
    (vl-remove-if '(lambda ( x ) (= (setq k (1+ k)) n)) l)
  (setq k -1)
  (vl-some '(lambda ( a ) (setq k (1+ k)) (if (vl-every '(lambda ( x ) (apply f (list a x))) (removenth l k)) (setq r a))) l)
  r
;;; (car-sort '(2 4 1 3 5 1) '<) => nil
;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
(setq yminpt (car-sort ptlst '(lambda ( a b ) (<= (cadr a) (cadr b)))))
Lee is right as usual... Consider using my (car-sort) function - should be fine with large lists, but be aware that when specifying sorting function '(lambda ( a b ) ... ) you don't use arguments the same as in (car-sort)... For ex. '(lambda ( x y ) ... ) will fail... Also, note that for comparisons you must use <= or >= instead like normal (vl-sort) < or > as like you see in example (car-sort) can't determine (< 1 1) as T and therefore return will be nil... (car-sort) will iterate just once and won't make further sorting of other elements - it will return just (car) element...
Regards, M.R.
