I found this lisp by Kent which enable the user to pick an entity and add "-DEMO" to its layer name, change its color and linetype which is working great.
Can this be modified to accept multiple selection rather than by pick only.
And if i select a block if does not change the color and linetype.
(defun c:DEMO (/ esel ent DLname)
  (while (setq esel (entsel "\nPick object to put on its Demo Layer: "))
    (setq
      ent (car esel)
      DLname (strcat (cdr (assoc 8 (entget ent))) "-DEMO")
    (command
      "_.layer" "_make" DLname "_color" 40 "" "_ltype" "HIDDEN2" "" ""
      "_.chprop" ent "" "_layer" DLname ""
Edited by CAD_Noob
typo error
Sure, I renamed the command CLCL
(defun change_layer_color_ltp ( ent /  DLname)
    (setq
      ;;ent (car esel)
    (command
(defun c:clcl ( / ss i)
  ;; selection
  (princ "\nMake selection: ")
  (setq ss (ssget))
  ;; now perform the function for every selected entity
  (setq i 0)
  (repeat (sslength ss)
    (change_layer_color_ltp (ssname ss i))
    (setq i (+ i 1))
Edited by Emmanuel Delay
  • Like 2
  • Thanks 1
    (setq
      ;;ent (car esel)
    (command
  ;; selection
  (setq ss (ssget))
  (setq i 0)
    (setq i (+ i 1))
Hi @Emmanuel Delay; thanks for this. Will try tomorrow as I do not have AutoCAD at home.
Thanks so much! working well.
Just need to edit some blocks to ByLayer for the routine to take effect.
Some blocks are a bit hard to edit though there are couples of nested block
Hi found a bug...
if the selected item happens to be in the demo layer already it again adds "-DEMO" suffix.
Example :
Before : A-_Door-DEMO
After : A-_Door-DEMO-DEMO
It's not a bug, it's user error for selecting an entity on a layer with the suffix "-DEMO" :lol:
A belt and braces lisp. You can't select a layer with "-DEMO" in the layer name
If the layer already has an associated "-demo" layer it moves it to that layer
Otherwise it creates the demo layer and moves it.
(defun change_layer_color_ltp ( ent /  dlname)
    (setq dlname (cdr (assoc 8 (entget ent))))
    (cond ( (and (not (wcmatch (strcase dlname) "*-DEMO"))
                 (setq dlname (strcat dlname "-DEMO"))
                 (not (tblsearch "layer" dlname))
            (command "_.layer" "_make" dlname "_color" 40 "" "_ltype" "HIDDEN2" "" ""
          ( (tblsearch "layer" dlname) (command "_.chprop" ent "" "_layer" dlname ""))
  ;; selection
  (setq ss (ssget '((-4 . "<NOT") (8 . "*DEMO") (-4 . "NOT>"))))
  (setq i 0)
    (setq i (+ i 1))
  • Like 2
  ;; selection
  (setq i 0)
    (setq i (+ i 1))
Thanks for the fix, sometimes some of those demo layers are accidentally selected when windowing
  ;; selection
  (setq i 0)
    (setq i (+ i 1))
one last request please? exclude xref from the selection...
  • 2 years later...
Hello,
Great code. Can this code be updated to include adopting the source line type and line weight of the layer picked?
Thanks
20 hours ago, grantm said:
Hello,
Thanks
That's quite another requirement.
Are you happy with this:
Command MCTW
- select a source element (line, or whatever).
- Then select a destination selection set.  The destination set gets the layer, color, line type, line weight of the source.
(I think it doesn't work perfectly if true color (RGB) is involved)
(vl-load-com)
(defun match_props ( ent layer col lt lw /  )
	(entmod (subst (cons 8 layer) 	(assoc 8 (entget ent)) 		(entget ent) ))  ;; substitute layer
	;; if this property is ByLayer, then it's empty and we have to add it.  else we substitute it.  Dito for follomwing If-statements
	(if (assoc 62 (entget ent))
		(entmod (subst (cons 62 col) 	(assoc 62 (entget ent)) 	(entget ent) ))  ;; substitute/add color
		(entmod (append (entget ent) (list (cons 62 col)  ) ))
	(if (assoc 6 (entget ent))
		(entmod (subst (cons 6 lt) 	(assoc 6 (entget ent)) 	(entget ent) ))  ;; substitute/add line type
		(entmod (append (entget ent) (list (cons 6 lt)  ) ))
	(if (assoc 370 (entget ent))
		(entmod (subst (cons 370 lw) 	(assoc 370 (entget ent)) 	(entget ent) ))  ;; substitute/add lline weight
		(entmod (append (entget ent) (list (cons 370 lw)  ) ))
;; Match Color, line Type, and line Weight of the layer picked
(defun c:MCTW ( / source layer col lt lw ss i)
;; select source, read its properties
	(setq source (car (entsel "\nSelect source: ")))
	(setq layer (cdr (assoc 8 (entget source))))	;; layer
	(setq col (cdr (assoc 62 (entget source))))	;; color
	(setq lt (cdr (assoc 6 (entget source))))	;; line type
	(setq lw (cdr (assoc 370 (entget source))))	;; line weight
;; select destination selection
	;; selection
	(setq ss (ssget))
	(setq i 0)
		(match_props  (ssname ss i) layer col lt lw)
		(setq i (+ i 1))
On 6/27/2022 at 8:15 AM, grantm said:
Hello,
Thanks
Here's another I've had in the toolbox for a while:
(defun c:layersuffix (/ e el l f s tm)
  ;; RJP - 04.03.2018
  (or (setq f (getenv "RJP_LayerSuffix")) (setq f (getenv "username")))
  (cond	((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm)
			    (f)
	      (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>"))))
	 (setenv "RJP_LayerSuffix" f)
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e)))))))
	   (or (tblobjname "layer" (setq nl (strcat l f)))
	       (entmakex (subst (cons 2 nl) (assoc 2 el) el))
	   (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e)))
Edited by ronjonp
  • 1 month later...
This is almost exactly what I was looking for, for our Engineering group.
I am terrible at manipulating LISP routines when it involves anything more than Find/Replace.
I am looking to make the layer DEMO-(Layer Name) instead of (Layer Name)-DEMO. Basically prefix instead of suffix. Is there an easy way to do this?
@turbosocks Give this a try.
(defun c:layerprefix (/ e el l f s tm)
  ;; RJP » 2022-08-12
  (or (setq f (getenv "RJP_LayerPrefix")) (setq f (getenv "username")))
  (cond	((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter prefix [<" f ">]: ")))) tm)
			    (f)
	      (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat f "*")) '(-4 . "NOT>"))))
	 (setenv "RJP_LayerPrefix" f)
	   (or (tblobjname "layer" (setq nl (strcat f l)))
  • Like 2
