hosneyalaa Posted March 25, 2020 Posted March 25, 2020 (edited) Hello all..... Sorry for my language I have a line or POLYLINE Written on it STATION Marking And the length is inconsistent with the station value if possible I want based on the value of the old stations When I click on a line or POLYLINE a new station value appears I found code TO dlanorh Needs modification of what I want Please provide us with appropriate ideas and solutions Who has the time? Thanks, thanks Attachment Pictures of the required And the working file STATION._REV_2010dwg.dwg Edited March 28, 2020 by CADTutor Reduced text size Quote
hanhphuc Posted March 26, 2020 Posted March 26, 2020 (edited) (defun c:test (/ n p1 p d $) (setq os (getvar 'osnapz)) (setvar 'osnapz 1) (initget 1) (and (setq n (getreal "\nStart STA : ")) (setq p1 (getpoint "\nStart pt ")) (setq $ (getstring (strcat "\nIncrement <Enter> or '-' \n"))) (while (setq p (getpoint p1 "\nNext point ")) (setq d (distance p1 p)) (setq d (if (wcmatch $ "-*") (- d) d ) ) (princ (strcat "\n" (rtos d 2 3) )) (entmakex (list '(0 . "TEXT") (cons 1 (_rtosta (+ n d) 3)) (cons 40 (getvar 'textsize)) (cons 10 (trans p 1 0)) ) ) ) (setvar 'osnapz os) ) (princ) ) Edited March 28, 2020 by hanhphuc 1 Quote
hosneyalaa Posted March 26, 2020 Author Posted March 26, 2020 (edited) HI hanhphuc Thank you If you have time I want you to be the distance linked to LENGTH POLYLINE , Especially if the POLYLINE contains an arc (setq e (entsel "\n SELECT POLYLINE "))) (setq p1 (getpoint "\nStart pt ")) (setq D0 (vlax-curve-getdistatpoint e p1); distance AT POINT p1 ON POLYLINE AND (while (setq p (getpoint p1 "\nNext point ")) (setq DW (vlax-curve-getdistatpoint e p1); distance AT POINT p ON POLYLINE (setq d (distance DW D0)) If possible, modify the code and add this idea Thank you STATION P_ARC ._REV_2010dwg.dwg Edited March 28, 2020 by CADTutor Removed unnecessary formatting Quote
