Hi all,  I need a lisp to add dimension to closed polyline, and is it possible to set all the dimension line only into the polyline?
Thanks in advanced.
dim.dwg
many examples just search ->  pdim by Marko
suppress arrow head looks tidy..
Thank you, is there a way to find out if a point is inside or outside of a closed polyline?
This code is from an old post here I have removed the color problem.
; code by Alanjt
(defun _isPointInside (polygon point / temp test)
 (if (vlax-curve-isClosed polygon)
   (progn (setq test (eq (length (vlax-invoke
                                   (setq temp (vlax-ename->vla-object
                                                (entmakex (list '(0 . "XLINE")
        '(100 . "AcDbEntity")
        '(100 . "AcDbXline")
        (cons 10 point)
        (cons 11 (trans '(1. 0. 0.) polygon 0))
                                   'IntersectWith
                                   (vlax-ename->vla-object polygon)
                                   acExtendNone
                         6
          (vla-delete temp)
          test
(_isPointInside (car (entsel "\nselect pline"))(getpoint "\nPick a point")) returns T
; code by Alanjt
        (cons 10 point)
                                   'IntersectWith
                                   acExtendNone
                         6
          (vla-delete temp)
          test
Thank you BIGAL, that was very helpful, I have another question :
I'm trying to run circle command for each item in list, but it's not working :(3 is radius)
lst = ((x1 y1 z1) (x2 y2 z3) (x3 y3 z3) ..)
(mapcar 'Circle (list lst) 3)
Try this
(repeat (setq x (length lst))
(setq pt (nth (setq x (- x 1)) lst))
(command "circle" pt 3.0)
2 hours ago, BIGAL said:
Try this
I knew it before, but I would write that with mapcar or lambda or apply. like this function for midpoint:
(defun mid (p1 p2)
  (mapcar (function (lambda (a1 a2) (/ (+ a1 a2) 2.0))) p1 p2) ;| #lambda |;
Edited by amir0914
Thinking a bit more its easily solved if you use is pline clockwise or anti, you can use Reveres to do just that on the pline. Then can use vertices as internal angle is always +90. Need though arc to be done differently. I have a check anti but I need a better one.
Your other question (foreach pt lst (Command "circle" pt 3))
Edited by BIGAL
Thanks for your reply, my first issue has been resolved by draw a ray and find out the point if is inside or outside of the polyline. now, only problem I have that is the dimension text string has overlap with other texts in polyline. do have a way for this problem?
