I am using ArcMap 10.3.1 and want to import auto CAD object . I follow this way : insert>import object
but there is an error :
"failed to create object. make sure the object is insert in the system registry?"
after search in google and find this answer , I disabled my Anti Virus but when I try to import Auto Cad after that ArcMap didn't work and I closed then try again and again but i can't to do this. -can someone help me to Import Auto CAD to ArcMap ? -I wan to change the format of auto CAD to geoJSON to work with my drawings in openlayers 3.
  • 3 weeks later...
Did you get this to work yet?
It's been a while since I worked with ESRI products but there was a way to add a layer(Arc Map Layer) to your project that is/are in dwg format. Look in the ArcMap help on using DWG/DNG files.
Look into making shp files I did not do this as we only pulled data from Esri and what was all written for us.
  • 1 month later...
thanks for you replies guys.
As you have AutoCAD 2020 you should have access to AutoCAD Map 3D. With this you can export your CAD file to a shp file.
