IDEA TO determinatING Location LENGTHS FOR POLYLINE
On 3/23/2020 at 7:00 AM, BIGAL said:
I think this explains here in AUS its 0-360 https://readcivil.com/bearing-in-surveying-definition-types-and-designation-of-bearing/ look at quadrant.
just my $0.02, maybe wcmatch angtos eg: "N*E,N" "N*W,E" "S*W,W" "S*E,S" ??
but OP's direction or quadrant quite confusing
(setq ang (angtos (angle p1 p2) 4 16) )
;"N 43d57'2.172254365\" E"
(wcmatch ang "N*E")
;T
(wcmatch ang "N*E")
;T
Yeah, though about that, but I think min bounding box might be the way forward. The bits work its just bolting it together.
Convex hull -> find longest segment -> rotate vertical -> boundingbox -> create frame -> rotate back. then get user to pick northern segment.
which northern quadrant (red zone)?
right diagram - quadrant bearing (angtos ang 4 )
left diagram - angle direction, preferable?
  • 5 months later...
On 3/24/2020 at 1:56 AM, dlanorh said:
@hosneyalaa Attached is attempt so far. This only works for clockwise polylines at present but I should be able to incorporate ccw polylines tomorrow.
Hope this is what you're after.
HI dlanorh
Is it possible to modify the LISP ?
And make writing lengths into POLYLINE
The accuracy of the number is two digits after the decimal point
4 hours ago, hosneyalaa said:
HI dlanorh
Attached is modified lisp so that text is inside. This lisp was also updated in May? as I improved some things, but I can't remember what (old age). :cry:
You can set the accuracy using (setvar 'luprec 2), before running the lisp (unless you want it hard coding)
Bearing_and_DistancePolyH.lsp
Edited by dlanorh
  • Thanks 1
