handasa Posted March 18, 2020 Posted March 18, 2020 HELLO EVERYONE HATCH AND BOUNDARY COMMANDS DOESN'T WORK PROPERLY ON THE OBJECTS SHOWN BELOW. THE CROSSED LINES INSIDE THE RECTANGLE CAUSES THE PROBLEM. IF I DELETE THEM THE HATCH AND BOUNDARY COMMANDS WILL WORK FINE.I TRIED CHANGING HATCH GAP TOLERANCE STARTING FROM ZERO TO 1000 WITHOUT ANY SUCCESS TO ESTABLISH HATCH AROUND THE RECTANGLE.ANY HELP? Quote
mdbdesign Posted March 18, 2020 Posted March 18, 2020 Did you try select object instead of pick point inside? 1 Quote
handasa Posted March 19, 2020 Author Posted March 19, 2020 16 hours ago, SLW210 said: Can you post the .dwg? HATCH PROBLEM.dwg Quote
handasa Posted March 19, 2020 Author Posted March 19, 2020 21 hours ago, mdbdesign said: Did you try select object instead of pick point inside? I HAVE TO USE PICK POINT INSTEAD OF SELECTING OBJECTS AS I USE HATCH COMMAND IN LISP Quote
handasa Posted March 19, 2020 Author Posted March 19, 2020 4 minutes ago, guran said: Set HPISLANDDETECTION System Variable to 2. this ignores the whole inside islands and create hatch filling the outer boundary Quote
mdbdesign Posted March 19, 2020 Posted March 19, 2020 Maybe, drop lisp you use and lisp gurus will try to help you. Quote
