Anushka Posted March 16, 2020 Posted March 16, 2020 How I adapt the program to get the name of the nearest block. with text it works. (defun :closestname (pt ss) (cdar (vl-sort (mapcar '(lambda (e) (cons (distance (cdr (assoc 10 (entget e))) pt) (cdr (assoc 1 (entget e))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) '(lambda (p1 p2) (< (car p1) (car p2))) ) ) ) Quote
dlanorh Posted March 16, 2020 Posted March 16, 2020 Quote 23 minutes ago, Anushka said: How I adapt the program to get the name of the nearest block. with text it works. (defun :closestname (pt ss) (cdar (vl-sort (mapcar '(lambda (e) (cons (distance (cdr (assoc 10 (entget e))) pt) (cdr (assoc 1 (entget e))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) '(lambda (p1 p2) (< (car p1) (car p2))) ) ) ) If you are only selecting blocks change (cdr (assoc 1 (entget e))) to (cdr (assoc 2 (entget e))) 1 Quote
Anushka Posted March 17, 2020 Author Posted March 17, 2020 (edited) @dlanorh It's YES!!! lol lol -1 worked Edited March 17, 2020 by Anushka Quote
dlanorh Posted March 17, 2020 Posted March 17, 2020 1 hour ago, Anushka said: @dlanorh It's YES!!! lol lol -1 worked Glad I could help. (assoc 2) is the actual name of the block, (assoc -1) is the entity name. Quote
