Why when i create a new view port in layout iwith same style (conceptual) i have different colors?
model3d.dwg
On 1/10/2020 at 12:54 PM, SLW210 said:
What are the Computer and Graphics Specifications?
Sorry i wrong post images. Try to see my dwg file .in model space and paper space ...
That's what I posted, the top is Layout and the bottom is Model, both look the same to me, but I am getting old.
I would guess it has to do with your computer, maybe someone else will chime in.
Do you maybe use a different background color in model and paperspace?
yes in model space i use rgb 240,235,214 in model space white
rgb 240,235,214 is not white, AutoCAD does try and make up for differences in background color most noticably when you use a white color it changes that to black on a white background. It would be worth trying to set both backgrounds exactly the same. That might not be the cause but try it.
ok thanks very much but now i remember that i use white even in 3d wireframe
Edited by jim78b
