Tenere Posted February 1, 2009 Share Posted February 1, 2009 Hi I'm getting to grips with sketchup 7 and have a window/door problem. I'm working on buildings that do not have square rooms (and have north lights). This means I am unable to push/pull out door and window openings which is a limitation well documented in the help, unfortunately an alternative is not given. Does any kind soul have a nice tidy solution up their sleeve to achieve these angled openings? thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 1, 2009 Share Posted February 1, 2009 How about doing it in Autocad and then Import to Sketchup? Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted February 2, 2009 Share Posted February 2, 2009 Tenere, i think you want to use the intersect command, you can draw a seperate block the size of the opening you require, then push it into position in the wall. Then select the wall & the opening block, then right click and select intersect with model. Now delete away your opening and any excess lines. Quote Link to comment Share on other sites More sharing options...
f700es Posted February 2, 2009 Share Posted February 2, 2009 Tenere, i think you want to use the intersect command, you can draw a seperate block the size of the opening you require, then push it into position in the wall. Then select the wall & the opening block, then right click and select intersect with model. Now delete away your opening and any excess lines. I agree, this should give you the result you are looking for. Quote Link to comment Share on other sites More sharing options...
boofredlay Posted February 3, 2009 Share Posted February 3, 2009 Here is a visual (screenshot) of the process if you want. Just make the opening the same size of your door. http://www.sketchucation.com/forums/scf/viewtopic.php?p=123527#p123527 Quote Link to comment Share on other sites More sharing options...
Tenere Posted February 3, 2009 Author Share Posted February 3, 2009 Thanks guys, sounds just the ticket. I must be a bit thick not to have ventured in that direction for myself, instead I was sat drawing in the geometry manually! - dohh. Help much appreciated. Quote Link to comment Share on other sites More sharing options...
