RS_Chip Posted March 10, 2020 Posted March 10, 2020 Hello, I'm facing a problem while extracting properties from Mtext's. How can we extract "defined height" and "Position Y" with VBA-code? Normal height, width, text i don't have problems, but those 2 that i need, i can't find a way. Can someone help me a little bit? Thanks! Quote
PeterPan9720 Posted March 10, 2020 Posted March 10, 2020 (edited) Here the code Sub SelectionSetFilterText() Dim MySelection As AcadSelectionSet Dim filterType(1) As Integer ' DIM to (0) if Not LAYER filter Applied in Selection Set Dim filterData(1) As Variant ' DIM to (0) if Not LAYER filter Applied in Selection Set Dim MyX, MyY, MyZ, MyWidth, MyHeight, MyWidth As Double Dim MyText As Variant Dim MyPosition() As Double On Error Resume Next On Error GoTo 0 For Each MySelection In ThisDrawing.SelectionSets If MySelection.Name = "PP1" Then MySelection.Delete End If Next Set MySelection = ThisDrawing.SelectionSets.Add("PP1") filterType(0) = 0 filterType(1) = 8 'LAYER SELECTION FILTER, DELETE IF DIM SET TO 0 filterData(0) = "TEXT,MTEXT" filterData(1) = "TAG" 'LAYER NAME SELECTION, DELETE IF DIM SET TO 0 MySelection.Select acSelectionSetAll, , , filterType, filterData For Each DWGSearchText In MySelection ' For Each Text find in the model space selection If DWGSearchText.Layer = "TAG" Then If TypeOf DWGSearchText Is AcadText Or TypeOf DWGSearchText Is AcadMText Then Debug.Print DWGSearchText.TextString ReDim MyPosition(UBound(DWGSearchText.InsertionPoint)) MyPosition = DWGSearchText.InsertionPoint MyX = MyPosition(0) MyY = MyPosition(1) MyZ = MyPosition(2) MyHeight = DWGSearchText.Height MyText = DWGSearchText.TextString MyWidth = DWGSearchText.Width 'Do something here End If End If Next End Sub Let me know if you will have any issue. Concerning the DEFINED HEIGHT I do not understand what you mean. With the above code you will have the text height (See MyHeight variable) Edited March 11, 2020 by PeterPan9720 Quote
RS_Chip Posted March 12, 2020 Author Posted March 12, 2020 On 3/10/2020 at 11:56 PM, PeterPan9720 said: Here the code Sub SelectionSetFilterText() Dim MySelection As AcadSelectionSet Dim filterType(1) As Integer ' DIM to (0) if Not LAYER filter Applied in Selection Set Dim filterData(1) As Variant ' DIM to (0) if Not LAYER filter Applied in Selection Set Dim MyX, MyY, MyZ, MyWidth, MyHeight, MyWidth As Double Dim MyText As Variant Dim MyPosition() As Double On Error Resume Next On Error GoTo 0 For Each MySelection In ThisDrawing.SelectionSets If MySelection.Name = "PP1" Then MySelection.Delete End If Next Set MySelection = ThisDrawing.SelectionSets.Add("PP1") filterType(0) = 0 filterType(1) = 8 'LAYER SELECTION FILTER, DELETE IF DIM SET TO 0 filterData(0) = "TEXT,MTEXT" filterData(1) = "TAG" 'LAYER NAME SELECTION, DELETE IF DIM SET TO 0 MySelection.Select acSelectionSetAll, , , filterType, filterData For Each DWGSearchText In MySelection ' For Each Text find in the model space selection If DWGSearchText.Layer = "TAG" Then If TypeOf DWGSearchText Is AcadText Or TypeOf DWGSearchText Is AcadMText Then Debug.Print DWGSearchText.TextString ReDim MyPosition(UBound(DWGSearchText.InsertionPoint)) MyPosition = DWGSearchText.InsertionPoint MyX = MyPosition(0) MyY = MyPosition(1) MyZ = MyPosition(2) MyHeight = DWGSearchText.Height MyText = DWGSearchText.TextString MyWidth = DWGSearchText.Width 'Do something here End If End If Next End Sub Let me know if you will have any issue. Concerning the DEFINED HEIGHT I do not understand what you mean. With the above code you will have the text height (See MyHeight variable) Hi PeterPan9720, The Position Y i got it. Thanks to you! The defined height is not the text height. It specifies the defined height of the MText, in other words, the height of the box forming the outer boundary of the MText. I'm still trying to find a way to get this... Quote
PeterPan9720 Posted March 12, 2020 Posted March 12, 2020 (edited) 32 minutes ago, RS_Chip said: Hi PeterPan9720, The Position Y i got it. Thanks to you! The defined height is not the text height. It specifies the defined height of the MText, in other words, the height of the box forming the outer boundary of the MText. I'm still trying to find a way to get this... Ok I understand, I'm not sure but you can try with : GetBoundingBox Method (ActiveX) object.GetBoundingBox MinPoint, MaxPoint https://knowledge.autodesk.com/it/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ITA/AutoCAD-ActiveX/files/GUID-A20C361C-BBF0-4EAB-8BE7-709154CEEE09-htm.html Method should return the bounding box around the object. MinPoint, MaxPoint represent set of x,y,z coords of lower left upper right corner. Edited March 12, 2020 by PeterPan9720 Quote
PeterPan9720 Posted March 12, 2020 Posted March 12, 2020 (edited) Hi, due to I'm curious, I tried a simple DWG with MTEXT on 2 lines, and bounding box Starting from the above routine I added the below code, after Mtext Object selection on DWG. So if you need the defined height, in the same way of previous object insertion point, you can retrive only Y values of MinPoint and MaxPoint and calculate the difference between retrieved Y value from MinPoint and MaxPoint. ----- DWGSearchText.GetBoundingBox MinPoint, MaxPoint Set Dline = ThisDrawing.ModelSpace.AddLine(MinPoint, MaxPoint) MyXMaxPoint = MaxPoint(0) MyYMaxPoint = MaxPoint(1) MyZMaxPoint = MaxPoint(2) MyXMinPoint = MinPoint(0) MyYMinPoint = MinPoint(1) MyZMinPoint = MinPoint(2) DifferenceY = MyYMaxPoint - MyYMinPoint DifferenceX = MyXMaxPoint - MyXMinPoint ------ and the line traced starting from Bounding Box coords received it has exactly dimensions of MTEXT frame. So if you check the value of DifferenceX it's exactly the DX of line traced, and equal to MTEXT Defined Width of course DifferenceY should be the Defined height, even if you check the properties on drawing this is to 0 and I don't know why. See attached dwg. Let me know. Bounding.dwg Edited March 12, 2020 by PeterPan9720 Quote
RS_Chip Posted March 12, 2020 Author Posted March 12, 2020 4 hours ago, PeterPan9720 said: Hi, due to I'm curious, I tried a simple DWG with MTEXT on 2 lines, and bounding box Starting from the above routine I added the below code, after Mtext Object selection on DWG. So if you need the defined height, in the same way of previous object insertion point, you can retrive only Y values of MinPoint and MaxPoint and calculate the difference between retrieved Y value from MinPoint and MaxPoint. ----- DWGSearchText.GetBoundingBox MinPoint, MaxPoint Set Dline = ThisDrawing.ModelSpace.AddLine(MinPoint, MaxPoint) MyXMaxPoint = MaxPoint(0) MyYMaxPoint = MaxPoint(1) MyZMaxPoint = MaxPoint(2) MyXMinPoint = MinPoint(0) MyYMinPoint = MinPoint(1) MyZMinPoint = MinPoint(2) DifferenceY = MyYMaxPoint - MyYMinPoint DifferenceX = MyXMaxPoint - MyXMinPoint ------ and the line traced starting from Bounding Box coords received it has exactly dimensions of MTEXT frame. So if you check the value of DifferenceX it's exactly the DX of line traced, and equal to MTEXT Defined Width of course DifferenceY should be the Defined height, even if you check the properties on drawing this is to 0 and I don't know why. See attached dwg. Let me know. Bounding.dwg 148.31 kB · 0 downloads Hello PeterPan9720, Once more you save the day. I can get everything i want now. Thank you very much. Its 0 in the properties, because for the property "Columns" = "Dynamic" you have in the options "Manual Height" selected. If you change it to "Auto Height", it will show the correct height. Thank you! Quote
PeterPan9720 Posted March 12, 2020 Posted March 12, 2020 17 minutes ago, RS_Chip said: Hello PeterPan9720, Once more you save the day. I can get everything i want now. Thank you very much. Its 0 in the properties, because for the property "Columns" = "Dynamic" you have in the options "Manual Height" selected. If you change it to "Auto Height", it will show the correct height. Thank you! Your welcome, I don't know the reason because the Defined Width and Height seems not accessible from MTEXT VBA Properties, however I'm happy you solved your issue. And in the same time I discovered some missing features with MTEXT. Regards Quote
