Dear All,
I Need help i have multiple layout and i want to do sheet numbering on each layout like 1/250,2/250.... how can i able to do this because if i do manually so it will take too much time is their any lsp or any short method to do the same i also attached my sample dwg
sample.dwg
Try this routine :
(defun c:numberpages ( / *error* objectid layoutof adoc aobj ct e o )
  (vl-load-com)
  (defun *error* ( m )
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (vla-regen adoc acactiveviewport)
  (defun objectid ( o )
    (vla-getobjectidstring (vla-get-utility adoc) o :vlax-false)
  (defun layoutof ( o )
    (vla-item (vla-get-layouts adoc) (cdr (assoc 410 (entget (vlax-vla-object->ename o)))))
  (setq adoc (vla-get-activedocument (setq aobj (vlax-get-acad-object))))
  (setq ct (getvar 'ctab))
  (foreach lay (layoutlist)
    (setvar 'ctab lay)
    (vla-zoomextents aobj)
    (setq e (ssname (ssget "_W" '(5800.0 2000.0) '(6200.0 2200.0)) 0))
    (setq o (vlax-ename->vla-object e))
    (vla-put-textstring o (strcat "%<\\AcObjProp Object(%<\\_ObjId " (objectid (layoutof o)) ">%).TabOrder>%" "/" "%<\\AcExpr %<\\AcObjProp Object(%<\\_ObjId " (objectid (vla-get-layouts adoc)) ">%).Count>%-1 >%"))
  (*error* nil)
Regards, M.R.
Edited by marko_ribar
Nicely done Marko.
Pmadhwal I would suggest you make your title into a block with  attributes, if for some reason your 1/250 is not at the position searched for, then code will fail. If its an attribute it can be found any where on the layout.
On 3/7/2020 at 6:54 PM, marko_ribar said:
Try this routine :
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (setvar 'ctab lay)
  (*error* nil)
Regards, M.R.
Thanks Sir perfectly working....many thanks
On 3/8/2020 at 4:46 AM, BIGAL said:
Nicely done Marko.
thanks for advice sir.......
