bruce13557 Posted March 3, 2020 Share Posted March 3, 2020 I'm using a plug in to name and count objects that I'm detailing. It labels them all in model space I am then inserting title blocks in paper space and dimensioning them. When I started all of the text in model space was printing nicely in paper space but somewhere it changed and now the text is printing very bold and is almost unreadable. As far as I can tell the text properties are the same for all of the printing. I have included 2 PDF drawings for comparison. Does anyone have a suggestion as to how I can fix it? 011 BIN CORNER 1 STRUCTURAL.pdf 036 FLOOR EDGE BEAMS.pdf Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 3, 2020 Author Share Posted March 3, 2020 I'm using AutoCAD 2020 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 3, 2020 Share Posted March 3, 2020 (edited) Looks like a change in text style but same name and possibly annotative. We always did not change "Standard" as a company policy no matter who drew what. Edited March 3, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 3, 2020 Author Share Posted March 3, 2020 THANKS I'LL CHECK IT Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 3, 2020 Share Posted March 3, 2020 Can you post some of the actual drawing file? 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted March 3, 2020 Share Posted March 3, 2020 Guessing Plot Style used for the added title block changed the lineweight for that text. It would be simple to figure out if you attached the drawing and Plot Style. Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 3, 2020 Author Share Posted March 3, 2020 My drawing is 37.7MB so its a little large to attach here unfortunately. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 3, 2020 Share Posted March 3, 2020 Wblock is your friend. Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 4, 2020 Author Share Posted March 4, 2020 I have tried changing the text style and even making a new one without any change, looking at the text closely it appears that the un readable ones have a much thicker line. Can I change the line thickness of multitext? Quote Link to comment Share on other sites More sharing options...
tombu Posted March 4, 2020 Share Posted March 4, 2020 1 hour ago, bruce13557 said: I have tried changing the text style and even making a new one without any change, looking at the text closely it appears that the un readable ones have a much thicker line. Can I change the line thickness of multitext? What font are you using? If you used Arial it shouldn't, but all shx fonts are subject to lineweight which could also be controlled by whatever Plot Style you're using. Have you tried changing the object or layer lineweight? If you using a CTB Plot Style have you tried changing to a color without lineweight? Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 4, 2020 Author Share Posted March 4, 2020 I am using Ariel, I did try Tecniclite without any change. I have tried changing layer, colour, and setting line weight to 0 and reducing line width without effect. It seems that this was put in with the add on (AVC LAY) when I was detailing Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 4, 2020 Share Posted March 4, 2020 23 hours ago, SLW210 said: Can you post some of the actual drawing file? As mentioned, just need some of the file, in particular the troublesome part. If just a little text is too large to post here, that may be part of the problem. Quote Link to comment Share on other sites More sharing options...
tombu Posted March 4, 2020 Share Posted March 4, 2020 4 hours ago, bruce13557 said: I am using Ariel, I did try Tecniclite without any change. I have tried changing layer, colour, and setting line weight to 0 and reducing line width without effect. It seems that this was put in with the add on (AVC LAY) when I was detailing All the TecnicLite and Ariel text came in fine. Easy to tell apart as 4's in TecnicLite don't close on top like they do in Ariel and TecnicLite was created with thiner lines. You've used some strange software to create those characters grey bounded by black characters. They look like ones used in ArcGIS and with some annotation created with AutoCAD Map but it cannot be created or converted by AutoCAD software or anything else I can think of. You must have some idea how you created that text or added it to your file. Time to fess up. Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 4, 2020 Author Share Posted March 4, 2020 Here is a sample of the text that I wblocked out. As I said it was placed using AVC Lay add on, https://sites.google.com/site/avcplugins/download Interestingly all the text is now clear in paper space so it must be a setting in my drawing new block.dwg Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 5, 2020 Author Share Posted March 5, 2020 Here is another drawing. I copied a viewport from the drawing into the wblock and the print view issue returned. Its the top drawing in paperspace. new block.dwg Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 5, 2020 Author Share Posted March 5, 2020 Finally worked it out Its an issue with printing in hidden view style Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 5, 2020 Share Posted March 5, 2020 On 3/3/2020 at 12:07 PM, tombu said: Guessing Plot Style used for the added title block changed the lineweight for that text. It would be simple to figure out if you attached the drawing and Plot Style. Yes it would have. Glad you have it sorted now. Quote Link to comment Share on other sites More sharing options...
bruce13557 Posted March 24, 2020 Author Share Posted March 24, 2020 I finally found the issue that was causing the problem. I turned off silhouette edges. Quote Link to comment Share on other sites More sharing options...
