How to update text value with x, y coordinate values automatically
Hi all,
I create a text entity with x, y coordinate value example as below (100.0 100.0 0.0)
(entmake (list (cons 0 "TEXT") (cons 10 (list 100.0 100.0 0.0)) (cons 40 25) (cons 1 "100.0,100.0")))
then I get the text entity info with:
Command: (entget (entlast))
((-1 . <Entity name: 17e9ede32f0>) (0 . "TEXT") (330 . <Entity name: 17eea97c700>) (5 . "467") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbText") (10 100.0 100.0 0.0) (40 . 25.0) (1 . "100.0,100.0") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))
then I select the text entity and move it to (297.46 231.108 0.0), but the text value is still "100.0,100.0"
((-1 . <Entity name: 17e9ede32f0>) (0 . "TEXT") (330 . <Entity name: 17eea97c700>) (5 . "467") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbText") (10 297.46 231.108 0.0) (40 . 25.0) (1 . "100.0,100.0") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))
I would like the text value is updated with new x, y coordinate value (297.46 231.108 0.0) automatically.
How could I do that with autolisp?
Thanks
Edited by long12345
1 hour ago, long12345 said:
Hi all,
Thanks
I don't think this is possible with text, but is possible with a block (see attached example dwg). The drawing contains a block (coords) which has a single attribute, which contains a field linked to the blocks insertion point. If you insert the block in will display the insertion point. If you move or copy the block you will need to do a regen.
coord.dwg
  • Thanks 1
Like Dlanorh you can use a mtext Field it would normally have something its tied to like a point, a end point and so on.
The simplest is to use a Autocad point you can display or not.
  • Thanks 1
Thank you.
So the solution is : Block + Attribute + Field...
Because this is a common case in autolisp world, it's good if there is a sample autolisp code for my reference.
How about event handing system in autolisp?
It's very easy to modify a dxf code value of a text entity such as this code from Lee Mac
(defun c:req ( / ent enx )
   (while
       (progn (setvar 'errno 0) (setq ent (car (entsel)))
           (cond
               (   (= 7 (getvar 'errno))
                   (princ "\nMissed, try again.")
               (   (null ent) nil)
               (   (not (wcmatch (cdr (assoc 0 (setq enx (entget ent)))) "TEXT,MTEXT"))
                   (princ "\nPlease select a text or mtext object.")
               (   (entmod (subst '(1 . "REQUIRED") (assoc 1 enx) enx)))
 May I catch a position change event then updating the text value with new x,y coordinate values?
when I open the attached file coord.dwg some label value is changed to ###### in my drawing file......
it's strange.......... I also see the function "s::startup-load" run that I never see before........
Edited by long12345
Thank you.
Now, I could select another Object such as : Line, Circle ........and see its Property......a kind of object oriented...
very helpful information for me......
You can actually achieve this with a self-referencing text field (though, this has to be created programmatically):
(defun c:test ( / o p )
    (if (setq p (getpoint "\nSpecify insertion point: "))
            (setq o
                (vla-addtext
                    (vlax-get-property (LM:acdoc)
                        (if (= 1 (getvar 'cvport))
                            'paperspace
                            'modelspace
                    (vlax-3D-point (trans p 1 0))
                    (getvar 'textsize)
            (vla-put-textstring o
                (strcat
                    "%<\\AcObjProp Object(%<\\_ObjId "
                    (LM:objectid o)
                    ">%).InsertionPoint \\f \"%lu2%pt3%pr1\">%"
            (vla-regen (LM:acdoc) acactiveviewport)
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:objectid ( obj )
    (eval
        (list 'defun 'LM:objectid '( obj )
            (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
                (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
               '(itoa (vla-get-objectid obj))
    (LM:objectid obj)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
  • Thanks 3
Thank you.
I know this Field expression
                    (LM:objectid o)
Do is posbile to the lisp ask me wich text I want to insert and give the coordinates to where be inserted?
HELLO LEE
PLEASE ADD FUNCTION   X=         , Y=        ,Z=
AND CHANGE FONT SIZE  AS PER DRAWING SCALE
  • 2 weeks later...
On 3/6/2020 at 6:08 AM, goyalx1d said:
HELLO LEE
With the permition of Lee-Mac
Maybe this can help you
COORX.lsp
HELLO LEE
;;;  LEE-MAC Programming
;;; Modified by PBG 20/03/01
;; https://www.cadtutor.net/forum/topic/69959-how-to-update-text-value-with-x-y-coordinate-values-automatically/?tab=comments#comment-562342
(defun c:coorx ( / o p ptoX ptoY ptoZ)
	(setq ptoX "%lu2%pt1%pr2%ls59%ps[X=,   ]%ds44%th46\">%")
	(setq ptoY "%lu2%pt2%pr2%ls59%ps[Y=,  ]%ds44%th46\">%")
	(setq ptoZ "%lu2%pt4%pr2%ls59%ps[Z=,]%ds44%th46\">%")
            (setq o
                (vla-addtext
                            'paperspace
                            'modelspace
                    (getvar 'textsize)
                (strcat
                    (LM:objectid o)
                    ">%).InsertionPoint \\f \"" ptoX
	   "\\U+000A"
                    (LM:objectid o)
                    ">%).InsertionPoint \\f \"" ptoY
                    (LM:objectid o)
                    ">%).InsertionPoint \\f \"" ptoZ
    (eval
    (LM:objectid obj)
(defun LM:acdoc nil
    (LM:acdoc)
With the permition of Lee-Mac, maybe this can help you
