jntm226 Posted February 28, 2020 Posted February 28, 2020 TL;DR I need to connect blocks using attribute values. I created multiple blocks and attribute with different properties (Annotative, scaled attribute text to 1:50, Upside down, Backward, Invisible, Constant, Verify, Preset, Multiple lines, Lock position, Visibility parameters) Request 1: I need to request for help to create a lisp for connect with *lines between attribute definition values since their attribute insertion point or block insertion point, ignoring all properties, included caps, but Visibility parameters not should be ignored, all this just of selected blocks (dynamic blocks, regular blocks, nested blocks). (check dwg attached for more details) Request 2: Add an option for let me choice if I need to ignore just specific attributes tag. (in the attached drawing I ignored between attributes values “tipo” and “nivel”) Request 2: Add an option for let me choice if I need connect just specific attributes tag. (in the attached drawing I connected between attributes values “codigo” and “alimentador”) Request 3: Add an option for let me choice for connect blocks insert point or attribute definitions insert point (check dwg file and images for more details) PD: attached blocks with the name “connect attributes.dwg” PD: if possible use DCL or OpenDCL for the GUI. connect attributes.dwgFetching info... Quote
