List Box with 4 panes (list boxes) - Insert Action
Hey Guys,
I am trying to write a lisp that has 4 or 5 list boxes. "LS1" would be the main list that appears on the first pane. When you click on "General" then second list box then would contain "LS2" as a sub category on the second pane. Then, if for example "LDF" from the second list/ pane is selected, "LS3" would show up on third list box and hopefully upon double clicking, it would insert a block from "LS3" list. Hopefully someone can follow my logic here and provide some help as to how to go about it.
Thanks guys.
The original lisp in done by Lee Mac in 2015
https://www.theswamp.org/index.php?topic=49169.0
(defun c:CABLE ( / *error* dch dcl des idx ls1 ls2 ls3 ls4 )
    (defun *error* ( msg )
        (if (and (= 'int (type dch)) (< 0 dch))
            (unload_dialog dch)
        (if (= 'file (type des))
            (close des)
        (if (and (= 'str (type dcl)) (setq dcl (findfile dcl)))
            (vl-file-delete dcl)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
(setq	ls1 (list "GENERAL" "BELL" "ROGERS" "VIDÉOTRON" "TELUS" "SUPPORT")
	ls2 (list "LDF" "AVA" "CNT" "AUTRE") ;; ls1 > "GENERAL"
        ls3 (list "LDF2-50A" "LDF4-50A" "LDF5-50A" "LDF6-50A" "LDF7-50A") ;; ls2 > "LDF"
	ls4 (list "AVA5-50A" "AVA6-50A" "AVA7-50A") ;; ls2 > "AVA"
	ls5 (list "CNT-300" "CNT-400") ;; ls2 > "CNT"
	ls6 (list "CAT5" "CABLE 2-0" "VXL7-50A" "RG6-FT1" "EWP132-144" "LMR-400") ;; ls2 > "AUTRE"
	ls7 (list "FO" "DC") ;; ls1 > "BELL"
	ls8 (list "FO" "DC") ;; ls1 > "ROGERS"
	ls9 (list "FO" "ALARME" "DC 2-CONDUCTEURS 4-AWG" "DC 12-CONDUCTEURS 8-AWG" "DC HYBRIDE 2-AWG"
		  "DC HYBRIDE 4-AWG" "DC HYBRIDE 6-AWG" "DC HYBRIDE 8-AWG") ;; ls1 > "VIDÉOTRON"
	ls10 (list "FO" "ALARME" "DC 2-CONDUCTEURS 8-AWG" "DC 6-CONDUCTEURS 8-AWG"
		  "DC 12-CONDUCTEURS 8-AWG" "DC 12-CONDUCTEURS 6x2x6-AWG") ;; ls1 > "TELUS"
	ls11 (list "LIST YET TO BE MADE") ;; ls1 > "SUPPORT"
); end setq
    (if
        (and
            (setq dcl (vl-filename-mktemp "tmp.dcl"))
            (setq des (open dcl "w"))
            (foreach str
                    "listbox : list_box"
                    "    width = 30;"
                    "    height = 40;"
                    "    fixed_width = true;"
                    "    fixed_height = true;"
                    "example : dialog"
                    "    label = \"CÂBLES ET LIGNES + SUPPORT DES CÂBLES\";"
                    "    spacer;"
                    "    : row"
                    "        : listbox { key = \"ls1\"; }"
                    "        : listbox { key = \"ls2\"; }"
		    "        : listbox { key = \"ls3\"; }"
		    "        : listbox { key = \"ls4\"; }"
                    "    ok_only;"
                (write-line str des)
            (not (setq des (close des)))
            (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "example" dch)
            (fill_list "ls1" ls1)
;;;            (action_tile "ls1"
;;;                (vl-prin1-to-string
;;;                   '(if (= 4 $reason)
;;;                        (setq ls2 (fill_list "ls2" (append ls2 (list (nth (atoi $value) ls1))))
;;;                              ls1 (fill_list "ls1" (LM:removenth (atoi $value) ls1))
;;;            (action_tile "ls2"
;;;                        (setq ls1 (fill_list "ls1" (append ls1 (list (nth (atoi $value) ls2))))
;;;                              ls2 (fill_list "ls2" (LM:removenth (atoi $value) ls2))
            (if (and (= 1 (start_dialog)) ls2)
                    (princ "\nThe user selected the following items:")
                    (foreach x ls2 (terpri) (princ x))
                (princ "\n*Cancel*")
    (*error* nil)
(defun fill_list ( key lst )
    (start_list key)
    (foreach itm lst (add_list itm))
    (end_list)
    lst
;; Remove Nth  -  Lee Mac
;; Removes the item at the nth index in a supplied list
(defun LM:removenth ( n l )
    (if (and l (< 0 n))
        (cons (car l) (LM:removenth (1- n) (cdr l)))
        (cdr l)
  On 2/28/2020 at 5:04 PM, Steven P said:
If you look at Lee Macs website, I am sure he has an example somewhere to do something similar (http://www.lee-mac.com/),  (http://www.lee-mac.com/listboxsync.html)if this is what you are meaning?
Expand
No. What I am meaning is the method to embed one list into another so when a keyword is selected, it leads to another list and another selection.
If you run the lisp, you may get a bit more information - it is harder to explain in words than you trying it.
Expand
Like this?
@Lee Mac
Hey Lee,
I created the list boxes, thanks to your great work, and was wondering if I could have your help in inserting blocks based on the selection.
Example:
C:CABLE
The user selected: GENERAL, LDF, LDF2 - 50A
"LDF2 - 50A" to insert a block.
Could you please let me know what variable I should be choosing to make a condition and whether or not it should be within the first (if ...) ?
Thanks again
;; DCL List-Tile Dependency  -  V1.1 (2019-04-27)  -  Lee Mac
;; Configures action_tile statements for the list of keys to enabled dependency between the DCL tiles.
;; key     - [lst] List of DCL tile keys in order of dependency
;; lst-sym - [sym] Quoted variable containing list data
;; rtn-sym - [sym] Quoted variable containing initial selection indexes
(defun LM:dcld:action ( key lst-sym rtn-sym )
    (defun LM:dcld:addlist ( key lst )
        (start_list key)
        (end_list)
    (defun LM:dcld:getlists ( idx lst )
        (if (cdr idx)
            (cons (mapcar 'car lst) (LM:dcld:getlists (cdr idx) (cdr (nth (car idx) lst))))
            lst
    (defun LM:substnth ( itm idx lst )
        (if lst
            (if (zerop idx)
                (cons itm (mapcar '(lambda ( x ) 0) (cdr lst)))
                (cons (car lst) (LM:substnth itm (1- idx) (cdr lst)))
    (defun LM:dcld:actions ( key lst-sym rtn-sym lvl / fun )
        (setq fun
            (if (cdr key)
                (list 'lambda '( val lst )
                    (list 'setq rtn-sym (list 'LM:substnth '(atoi val) lvl rtn-sym))
                    (list 'LM:dcld:addlist (cadr key) (list 'nth (1+ lvl) (list 'LM:dcld:getlists rtn-sym 'lst)))
                    (list
                        (LM:dcld:actions (cdr key) lst-sym rtn-sym (1+ lvl))
                        (list 'set_tile (cadr key) "0") 'lst
        (action_tile (car key) (vl-prin1-to-string (list fun '$value lst-sym)))
        fun
    (mapcar 'LM:dcld:addlist key (LM:dcld:getlists (eval rtn-sym) (eval lst-sym)))
    (   (eval (LM:dcld:actions key lst-sym rtn-sym 0))
        (set_tile (car key) (itoa (car (eval rtn-sym))))
        (eval lst-sym)
;; DCL List-Tile Dependency  -  Get Items  -  Lee Mac
;; Returns a list of the items selected from each dependent list tile.
;; idx - [lst] List of selection indexes
;; lst - [lst] List data
(defun LM:dcld:getitems ( idx lst / tmp )
    (if (cdr idx)
        (cons (car (setq tmp (nth (car idx) lst))) (LM:dcld:getitems (cdr idx) (cdr tmp)))
        (list (nth (car idx) (car lst)))
;; Two List Tile Dependency Example  -  Lee Mac
;; Requires ListTileDependency.lsp to be loaded.
(defun c:CABLE ( / *error* dch dcl des lst rtn )
            (close des)
        (if (< 0 dch)
            (unload_dialog dch)
        (if (and (= 'str (type dcl)) (findfile dcl))
(setq lst
;;;("ITEM1"	("ITEM-1A"	("ITEM-1A1" "ITEM-1A2"))
;;;		("ITEM-1B"	("ITEM-1B1" "ITEM-1B2" "ITEM-1B3"))
("GENERAL"	("LDF"		("LDF2 - 50A" "LDF4 - 50A" "LDF5 - 50A" "LDF6 - 50A" "LDF7 - 50A"))
		("AVA"		("AVA5 - 50A" "AVA6 - 50A" "AVA7 - 50A"))
 		("CNT"		("CNT - 300" "CNT - 400"))
 		("AUTRE"	("CAT 5" "CABLE 2 - 0" "VXL7 - 50A" "RG6 - FT1" "EWP132 - 144" "LMR - 400"))
) ;END GENERAL
("BELL"		("FO"		("BELL FO"))
 		("DC"		("BELL DC"))
) ;END BELL
("ROGERS"	("FO"		("ROGERS FO"))
 	 	("DC"		("ROGERS DC"))
) ;END ROGERS
("VIDÉOTRON"	("FO"		("VIDÉOTRON FO"))
		("DC"		("DC 2 - CONDUCTEURS 4 - AWG" "DC 12 - CONDUCTEURS 8 - AWG" "DC HYBRIDE 2 - AWG""DC HYBRIDE 4 - AWG" "DC HYBRIDE 6 - AWG" "DC HYBRIDE 8 - AWG"))
 		("ALARME"	("VIDÉOTRON ALARME"))
) ;END VIDÉOTRON
("TELUS"	("FO"		("TELUS FO"))
		("DC"		("DC 2 - CONDUCTEURS 8 - AWG" "DC 6 - CONDUCTEURS 8 - AWG""DC 12 - CONDUCTEURS 8 - AWG" "DC 12 - CONDUCTEURS 6 x 2 x 6 - AWG"))
 		("ALARME"	("TELUS ALARME"))
) ;END TELUS
("SUPPORT"	("ITEM-A"		("ITEM - A1" "ITEM - A2"))
 	 	("ITEM-B"		("ITEM - B1" "ITEM - B2"))
) ;END SUPPORT
) ;END MASS PARAN
) ;END SETQ
    (if
        (and
            (foreach str
                    "lbx : list_box"
                    "    alignment = centered;"
                    "    width = 35;"
                    "    height = 15;"
                    "test : dialog"
                    "    label = \"CÂBLES / LIGNES ET SUPPORT DES CÂBLES\";"
                    "    spacer;"
                    "    : row"
                    "        : lbx { key = \"lb0\"; label = \"CATÉGORIE PRINCIPALE\"; }"
                    "        : lbx { key = \"lb1\"; label = \"SOUS-CATÉGORIE\"; }"
		    "        : lbx { key = \"lb2\"; label = \"BLOC\"; }"
                    "    spacer;"
                    "    ok_cancel;"
            (new_dialog "test" dch)
            (setq rtn '(0 0 0))
            (LM:dcld:action '("lb0" "lb1" "lb2") 'lst 'rtn)
            (if (= 1 (start_dialog))
                (princ
                    (strcat "\nThe user selected:"
                        (substr
                            (apply 'strcat
                                (mapcar '(lambda ( x ) (strcat ", " x))
                                    (LM:dcld:getitems rtn lst)
                            2
    (*error* nil)
); END DEFUN
No worries! I found my way!
(setq luckylist (LM:dcld:getitems rtn lst))
(setq luckylist (nth 2 luckylist))
	(cond
		((= luckylist "LDF2 - 50A")(alert "LDF2 - 50A is Selected"))
		;the rest
Thanks
